Old 01-05-2010, 04:20 AM
AUdubon5425's Avatar
That model is covered by Sams 1503 (1975) - E111, E113, E114 (per Sams online index.)
Old 01-05-2010, 10:36 AM
I figured I would give in one more email (2 so far nothing) prob a throw away email acct. oh well no big deal I have plenty to keep me busy, and I really prefer something a little older anyway. Guess for free you can not expect much in the way of courtesy.
Old 01-08-2010, 12:59 PM
25vdmp22 sylvania tube
All SS
The lady had gotten a bunch of no shows early on so had stopped responding (i can understand that).
Anyway got it home in one piece.
I will put it on the CRT checke later.
Or should I just go for it? do you variac SS sets, I have no idea about a powr up procedure. Dont want to smoke anything if possible.
Old 01-08-2010, 02:15 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Never really dealt with the SS sets, however, I'd lean towards pluggin it in and lettin 'er rip! Those sets won't have any paper caps, and in the big scheme of things, it isn't very old (only 1975). Probably doesn't use any black beauties, either. I'd just give it a good visual inspection looking for anything obvious. You could run your amp meter with it to make sure it isn't drawing too much current when you first fire it up.
Charlie Trahan
Old 01-08-2010, 02:28 PM
I'd give it the visual once over. If I didn't see anything wrong, I'd fire it up.
Old 01-08-2010, 03:13 PM
ctc17 ctc17 is offline
Are all the transistors socketed in this one? I had a table top of that age that was very well built.
Old 01-08-2010, 03:53 PM
I will get a pic of the chassis later, looks solid built.
Old 01-08-2010, 04:03 PM
Pics, CRT has a kinda washed out looking center area
Old 01-08-2010, 04:27 PM
power up, tuner working (getting audio) HV is at the anode (30kv) but its like the CRT is completly cut off. very very dim no discernable pic. when you turn it off and on you get a flash of light.
No raster ohter than the same very very dim effect.
Gong to check the pic tube next.
Old 01-08-2010, 04:41 PM
CRT test very good.
So its just being cut off, I guess the next step would be to confirm by checking the voltages at the CRT?
All the filaments light (stay lit, so must have some dumb instant on feature some were).
Gonna need a Sams on this on guys.
Old 01-08-2010, 04:44 PM
There were a couple suspect looking caps on the CRT pin board, a brown dip
.22 uf 100v... not very big either.
Gonna need a lot of help here as I no nothing about trouble shooting TV's with IC in them (at least they are all socketed). If I need replacement IC are they still available?
Old 01-08-2010, 05:38 PM
.22 check ok
can some one tell me what voltages I should be seeing from the K to the G1 and G2 on the guns? with no signal (just raster).
Old 01-08-2010, 05:46 PM
K to G1 -200vdc
K to G2 +500vdc
Seem like -200vdc would certainly cut off the emissons.
Old 01-08-2010, 05:55 PM
going to mess with the brightness control to see if there is any effect on the G1 voltage.
Old 01-08-2010, 06:43 PM
Hmmm brightness control has no effect at all on the K to G1 voltage. I thought it should.
