Old 11-20-2009, 09:53 PM
coffee123 coffee123 is offline
This is some great info...ive got two clock radios, a zenith and a motorola I need to start fixing up, needs a re-cap, re-resistor.....and im sure the clocks will be noisy
Old 01-03-2010, 12:32 AM
Adam's Avatar
Adam Adam is offline
I finally looked at this 1957 RCA clock radio I got when I started this thread. I had assumed the clock was like the others I had seen, where the mechanism is sealed, but that wasn't totally the case here, couldn't get it totally apart, but got a cover off and got in there enough to squirt some WD40 in there, which so far has quieted it down.
The radio portion had a corner broken off the circuit board, but I glued it back together with super glue, waited until I was sure it was dry, then just added solder across the one trace that went across the corner, I was going to add a wire in it's place, but it soldered up good, so I left it like that. Other than new caps, the radio just needed a new 50C5 to replace the one in there with an open filament. Now I finally have a good old, quiet clock radio.
Old 01-03-2010, 01:44 AM
Charlie's Avatar
Charlie Charlie is offline
On Land
I've got that same clock radio... except the clock's face is black i think. Yours is in better condition than mine. Both clock and radio on mine work... but the radio could use a little work.
Charlie Trahan
Old 01-04-2010, 09:52 PM
rollei35guy rollei35guy is offline
Does that disk on the back of the radio spin out in the open? I've seen a couple of clocks like that but not, so far, in a radio.
That's a nice looking radio you have there. Very clean.
Old 01-04-2010, 10:41 PM
Adam's Avatar
The cover you see on the back of the clock pries off, and then you can see some of what's moving in there. I ran it for a couple hours after I got it working, and the clock started to get a little noisy again, then I left it unplugged for a day or so, tried it again, and it was quiet again, but I still left it unplugged. I'm thinking I might try and get some oil in there, rather than just the WD40.
Old 01-06-2010, 08:04 PM
Reece's Avatar
Reece Reece is offline
Adam, that radio looks like it was just bought yesterday!
Reece
Old 01-06-2010, 10:04 PM
Adam's Avatar
I polished it up with some of that novus #2.
