Old 04-09-2009, 06:50 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Question Variac or not?
I've worried about whether bringing a TV up on a variac is appropriate or not. The concern is the sweep section. If it doesn't start oscillating because of low voltage there are a few bad things that can happen.
I did a little searching and found conflicting answers.
Pharis-video recommends bringing a set up starting at 25VAC and increasing it 5 volts every 5 minutes.
Amptechsystems recommends against using a variac because of the concern that I mentioned.
A variac works great on radios and gives the electrolytics, new or not, a chance to reform. I'm not so sure about televisions.
Has anyone had a bad experience using a variac?
