Well, not so much complex, but made with cryptic layouts, tiny, hard to read numbers, and unlabeled IC's that could be for pretty much anything...
This is kinda on topic, but not really. However, I don't see a board for chainsaws anywhere.
I found an old Montgomery Wards electric chainsaw. It's easy to take apart and clean. The chain that was on it is quite dull. Not having access to a suitable file, I switched it out for another, better chain. It also has a small oil tank which I filled. The chainsaw works pretty good. I cut through a 6 inch thick log without too much trouble. So, two Montgomery wards products, both from the 80's (the chainsaw may be older), and both were easy to fix. |
I think both Penneys and Montgomery Wards had some very good units. First thing to look for is Made In Japan on the back.
Now, while at that time, Admiral was practically a Wards house-brand as far as consumer electronics were concerned, I did notice that TVs bearing the "real" Wards house brand ("Signature 2000") were not re-badged Zeniths; I seem to recall that they appeared to be Sanyo-made, but I might be misremembering that. |
| Audiokarma |
Bryan |
You're right about that option in the Zenith service menu-- it's the "ZEN/PL" mode select option at least on some early/mid-90's Zenith-made sets. I tried that once long ago on a 1993 25" Zenith which was my main TV at the time. If I remember correctly, setting it to "PL" (Private Label) not only altered the labeling of some of the OSD menu items, but it also removed a few of the menu options entirely. I suppose if someone wanted to save a few bucks at the time, they could have bought a "private-label" Zenith, then gone into the service menu and turned it into a "real" Zenith set. ![]() ...Not that doing that would have improved the reliability of the CRTs they were using at the time, however. ![]() The service menu was pretty cool though. At least on some Zenith lines, the service menu included a number of settings that were obviously intended for hotel/business/institutional applications. At the time, I figured that if I ever encountered a *really* annoying salesperson at a store that sold Zenith TVs, I thought the following procedure would be a funny (read: mean) practical joke to pull. Go into the service menu on one of the display models in the store, then enable the "power set on automatically when AC cord plugged in" option, set the default power-on channel to an active channel, set the minimum/power-on sound volume to its maximum, and disable the front panel controls. Then, exit the service menu, power off or unplug the set and (quickly) leave the store. At most mass-merchandisers, if someone did that, I wonder if the anyone working there would ever figure out what happened or how to fix it.
