Old 06-18-2008, 11:10 AM
MRX37 MRX37 is offline
Okay, I thought I'd post the steps to do advanced convergence for the CTC 195 chassis, just in case someone runs across one of these TV's and has a similar issue:
To access the service menu, you hold down the "Menu" button on the front of the TV, then press the "Power" button and the "Volume +" button. You should see something on the screen that looks like:
"P 0 V0"
Press the "Volume +" button on the front of the TV until you get to the number "80" next to the V on the screen, then hit the channel up button on the TV. You should now see a grid on the screen.
The channel and volume up buttons on the remote control move the + in the middle of the grid up, down, left, and right. The arrow keys on the remote, normally used for navigating the menu, will move the color that you are trying to converge.
You can only select between Red and Blue to converge onto Green. The "Info" or 'Display" buttons on the remote will change between red and blue. The + will turn yellow for red adjusting, and Cyan and blue adjusting.
After you're done, you can exit the menu by pressing the "power" button on the remote.
Old 06-18-2008, 11:54 AM
000
