Old 06-03-2008, 10:03 PM
NowhereMan 1966's Avatar
Slave to 1 Cat
2 Zeniths here and they are used everyday, sometimes a lot. The "TV" in my bedroom is a Commodore 1702 monitor so the Zenith DTV box is the only tuner so I only get ATSC there. (Crossing fingers) So far, so good. I guess like anything else, there are a few lemons out there. I'd take it back and exchange it.
Old 06-04-2008, 10:59 AM
jhal's Avatar
jhal jhal is offline
Titanium bliss
I will be picking up 4 convertor boxes, probably Insignia's since BB is closest, in the next couple of days for myself and for my 95 year-old grandmother's house. We both have satellite (Direct TV), but it cuts out during heavy rains. I can always tell when it's getting ready to rain hard, because the signal cuts out about 1-2 minutes beforehand.
On a sidenote, I am still unable to find a battery powered TV set that can pickup over the air digital broadcasts for use during hurricanes and other bad weather when the power goes out for long periods of time. Best buy no longer carries the Insignia model they had last year. I just hope this need is met in time for next year's "Hunker down, we're all gonna die!. There's a storm off the coast of Africa!" storm season.
JBL XPL-200A's biamped on Yam. PC2602M & M-2 amps with
Ashly XR1001 xover, Yam. CX-830 preamp,
ADC Sound Shaper 2 EQ, Yam. Q-2031 EQ
Yam. DX-350 tuner, Tech. SL-1400 turntable,
Yam. CDX-900U cd, Pan. DVD-RP56 dvd,
Den. DRR-780 tape, Sony SLV-575UC vcr
Old 06-04-2008, 05:12 PM
OvenMaster's Avatar
DTV blows
I've been using a Magnavox for almost 3 months. I leave it on almost 24/7 because I videotape TV shows for other family members. The only issue seems to be less-than-stellar performance with weak signals. The top of the case also gets mighty hot. Other than that, it's been rock-solid.
Tom
Tom
Old 06-04-2008, 06:59 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Is it the power supply that gets mighty hot? Or the tuner/RF modulator?
If the PS, then there's several reasons now to use an outboard power supply.
1) it runs cooler.
2) it runs less noisy (RF interference on Ch3 on older sets)
3) it runs less noisy (spikes hard on internal components)
4) it could run on battery!
5) it's a reason to get out the soldering gun and play.
Especially bullet 4, I'd like to modify one to run on NiCad pack or car battery for use with a battery-powered TV during outages.
Except of course if the outage is caused by a storm, in which case the digital signal will probably block and drop anyway, so it would be moot.
Do not attempt to adjust your set.
Old 06-04-2008, 07:10 PM
How about a battery powered radio that receives weather channels? My car radio picks up weather channels.
TV coverage of bad weather verges on the ridiculous, anyway. "Hi, this is Brandi Boogaloo standing outside the Boogie-Woogie Arms Motel in Tampa Bay. Look -- it's really really windy and some trees are bending over! Back to you at Hurricane Central, Chaz!!"
P.S. No problems using a Zenith box here.
Old 06-04-2008, 08:05 PM
peverett peverett is offline
Having TV coverage, espcially the radar images. is almost a necessity here in the central US with the tornados, severe thunderstorms, etc. This is much better than the radio can do.
This is the main reason that I think getting rid of analog NTSC is completly stupid. Analog NTSC will provide usuable (not perfect by any means) information in bad weather for a long while after digital has completly crapped out.
As a case in point, my digital reception was glitching yesterday and the only issue was that it was a little windy. As I am only 30 miles or so from the transmitters, I do not think power is the issue(I believe the issue is the transmitting antenna moving in the wind).
Old 06-04-2008, 08:19 PM
tcdriver's Avatar
tcdriver tcdriver is offline
Have your unit repaired under warranty.
My Zenith DTT900 has a 90 day warranty from the "Date of Purchase". The parts warranty period is one year.
Round and Round it goes
Old 06-04-2008, 09:01 PM
zenith2134's Avatar
We'll see how this all turns out.
They'll probably boost power a good amount if people aren't getting usable signal.
Old 06-04-2008, 09:10 PM
jhal's Avatar
Titanium bliss
1) it runs cooler.
#4 is a very good idea! I will have to open up one of mine when I get it to see how easy (or hard) it would be to add a DC jack and a switch to choose between internal and external p/s's.
Old 06-04-2008, 10:42 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
Well,
I'm the first to have the first DTV converter box failure, or atleast the first to report a failure on AK. I have the zenith converter box which is sold at circuit city, which is the same as the insignia box sold at best buy. While watching TV this evening with the box, the screen all of a sudden went into intermittent blue horizontal bars and then the unit shut off. I attempted to turn it back on and nothing. The red LED which is on when the unit is switched off even went out so its dead as a door nail now. No reset button on the unit. Wont respond to anything, remote or at the unit. Perhaps something in the power supply failed. Ive yet to investigate. Too late to get into that now. All I can say is that this is pretty poor. Ive only had the box about 1.5 months and it broke already. Im curious if more will fail as time passes in the near future.
This digital transition is a joke. More BS to deal with. Cheap crap converter box is an insult to the Zenith name. I think the quality fell out before the name went on with this thing. Whats next.
Did the box get hot when it was still working? The poorly ventilated enclosures so common on modern electronics often cause SMD components to unsolder themselves from the boards. I've had similar problems with multiple wireless routers in the past few years.
Old 06-04-2008, 10:52 PM
OvenMaster's Avatar
DTV blows
1) it runs cooler.
From what little I've been able to see, it's possibly some of the digital circuitry that causes the heat! One time I'd left the converter on a blank subchannel overnight, and when I went to pick up the remote in the morning (I park the remote on top of the box) the box was barely more than room temperature.
Tom
Tom
Old 06-04-2008, 10:55 PM
Chad Hauris's Avatar
Doug, can you see what the failure mode was and if an external supply can be rigged up for them. I really depend on the converter boxes to get a good quality TV signal and would like to keep them going...hopefully its not a case like on some DVD players I've heard of where there is no overvoltage protection and a power supply failure burns out chips on the board.
Chad Hauris
Old 06-04-2008, 10:58 PM
fsjonsey's Avatar
You could cut a hole in the top of the case and install a small computer fan to help with cooling.
Old 06-04-2008, 11:02 PM
I got some DTV coupons I haven't used yet so I think I'll get a second insignia and measure the voltages from the power supply in a normal condition...that way I may be able to hook up an external supply and know what voltages I'll need.
Chad Hauris
Old 06-05-2008, 07:51 AM
tomwil's Avatar
tomwil tomwil is offline
This Radio Shack model, although currently sold out on the web, is still available in the stores.
http://www.radioshack.com/product/in...ductId=2855063
"Sometimes I get this crazy dream
That I just take off in my car
But you can travel on 10,000 miles
And still stay where you are"
- Harry Chapin
