Old 05-26-2008, 12:27 PM
ablethevoice's Avatar
ablethevoice ablethevoice is offline
boatanchors rule!
Location: NW FloridHell panhandle. Ivan and Dennis survivor.
I went ahead and tried to fix it because I didn't want the idiot who damaged it to be successful. So far it's working well. I had to go back once and fix a loose wire. That's the tip of a small xacto knife blade for scale. The wires I used aren't much bigger than a human hair. My main worry is about all the mechanical stress that was placed on the cable, driver ICs, and the bonded connection to the panel. The ICs are glued to the cable with a blob of epoxy, so there's nothing to solder to directly. The cable is made of a high temperature plastic that doesn't melt, so it wasn't too hard to solder to (apart from the size). I'm glad I still have young eyes!
You can see why these things cost so much. The actual TV and plasma drive electronics are fairly simple. Most of the electronics are in the power supplies. There are about 8 complex switching power supplies. I hope this thing doesn't develop bad caps because there are dozens of them.
Andy, that's incredible! Knowing myself as well as I do, I know I'd have never had the patience to attempt what you successfully achieved! Even if you don't follow through with this, you can have the satisfaction of knowing that stemcase knob didn't win.
Old 05-26-2008, 12:44 PM
MRX37 MRX37 is offline
I'm very glad you fixed it. So, how's the picture? Comparable to CRT? Better?
Old 05-26-2008, 12:52 PM
DENNYDOG's Avatar
DENNYDOG DENNYDOG is offline
PIONEER Lover :)
Originally Posted by Twenty20Man View Post
great repair in a tough situation..good job. I would go to BOTH repair shops and speak to the owner with the pictures. perhaps the dishonesty is just at the bottom. armed with this information the owner can watch for similar practices in his shop..who knows..but i know this it will never stop if people dont follow up and bring this stuff to light..
I agree.
It reminds me so much of this thread in the Wheels, Wings, Mud and Water forum. http://www.audiokarma.org/forums/sho...d.php?t=166241
Bastards I tell you!!!
Nice repair job btw. I think I would have tried to fix it myself also. You really have anything to lose in situations like this.
Denny
The ability to use a machine to make something is not 'manual labour' or 'production work' - it is a skill.
Old 05-26-2008, 02:40 PM
Exclamation
Heard it said that the "pin in the flyback" was a common sabatoge back in olden vacuum tube TV days.
Old 05-26-2008, 02:47 PM
junkaudio's Avatar
junkaudio junkaudio is offline
glad it worked ,repair on new units ain´t easy
a life without music is a mistake
Old 05-26-2008, 03:39 PM
Lady Ayeka Lady Ayeka is offline
DAMN!! i don't know how you did that! incredible!!
Old 05-26-2008, 03:57 PM
ccheath's Avatar
ccheath ccheath is offline
Got an Idea!
Steady hands and patience. Way to go Andy!
Old 05-26-2008, 04:33 PM
Nikko75's Avatar
Nikko75 Nikko75 is offline
Audio Aficionado Engineer
Technicians and mechanics...there are good ones but they are far and few between! There's a guy here who is licensed by Marantz and his idea of a repair was to bypass an entire section of a tube amp.
PS.Good work there!
Old 05-26-2008, 11:29 PM
brokenbroken's Avatar
brokenbroken brokenbroken is offline
I wouldn't doubt if the owner or owners is behind it. I work at a shop that does repairs and although it hasn't happened in a few years there were times when a customer would refuse our repair. I was instructed by the owner to make the set unrepairable. When I of course refused to do that, he did it himself.
Old 05-26-2008, 11:32 PM
Old 05-27-2008, 12:13 AM
Nice repair job, Andy! You must have the patience of Job!
What was the reasoning behind that? It seems like it could only hurt the shop if it was ever discovered.
Actually, I do recall an incident that bit the repair shop in the butt that I mentioned above.
Someone brought in a nice 19" Magnavox set (and other electronics) for repair that had been hit by lightning. The TV turned out to be a routine repair, only needing a fuse and rectifier diodes. Well, the repair tech wanted the set for whatever reason and lied to the customer, telling them that lightning burnt it up and it could not be repaired. The customer called the shop back and told them that their insurance agent needed to see the damage to the set, as well as the other electronics that were damaged. This dishonest crook then takes 110 volts and runs it all over the chassis, totally burning it up and making it unrepairable. A few days later, the owners called the repair shop and said "you can do what you want with that set. The insurance people don't need to see it".
When the repair guy told me that, I told him how crooked he was and what happened was good enough for him.
I too don't understand why shops do this sort of thing. Why not just put it back together like they found it or remove their new parts if they've fixed it and the estimate is refused? The only reason I can come up with for such childish behavior is they are afraid that the customer will take the set to another shop and get the work done cheaper. That would likely cut them out of any future repairs by that customer. So, they ruin the equipment to make sure no one else can fix it.
Old 05-27-2008, 01:10 AM
Nowadays, with new electronics only costing maybe twice what a repair shop might charge to fix the old one, most people, given the uncertenty of the skill and honesty of repair shop, will just toss the broken one and buy the new device. It's a no-brainer if it's a DVD player.
Old 05-27-2008, 07:10 AM
Electronics Accumulator
Nice job Andy! See, I knew you could fix it.
-Ian
Old 05-27-2008, 10:13 PM
karmaman's Avatar
karmaman karmaman is offline
I'll never understand the mentality of people like that. What the hell does it matter to them if someone ends up repairing it? You'd think they would be happy someone was able to get use out of their junk. Pure greed.... personally, I get pretty happy when I see someone make use out of my old junk. I'd much rather see that than to throw away good or easily repairable stuff.
Anyway, Andy, kudos on the EXCELLENT repair. I'll never understand how you were able to do that, but seriously, good job man.
EDIT: Oh, Andy, I just remembered you were hoping the PSU won't develop bad caps. Give me a pic of the Power Supply board(s) that clearly shows some of the caps or the brands and series of the caps and I can tell you if they will fail or not. I've got a lot of experience with caps from working with computers. If the caps are Nichicon, Rubycon, Matsushita/Panasonic, Nippon Chemicon, or Fujitsu, they probably won't fail.
Old 05-27-2008, 11:03 PM
waltchan waltchan is offline
Despite Andy's successful repair, why would he take a Dell plasma TV? There's nothing special about a Dell plasma TV and there's no character.
