Old 01-27-2008, 07:52 PM
rcaman's Avatar
rcaman rcaman is offline
Originally Posted by rcaman View Post
This TV had no Picture on the top half of screen and some retrace lines in the center of screen . I found 2465 10uf @ 160v completely open. 2446 was 2/3 of it rated capacity at 470uf @ 16v. Replacing them was no help. I Found surface mount diode 6460 shorted. The diode is a 482213011397 nla but NTE633 will replace it. I used a nte177 to replace it and it appears to be fine. Could be a common problem when these cap go off value. Figured I would post it here
_________________
this is from my tech board the best techs in the country are there. steve
this fix is for you chassis
