Old 12-29-2003, 10:38 AM
That looks like very similar to the remote chromacolor II I found last week. What's the small rectangular object just above the channel display? Mine just has the Zenth logo across the top.
Those Pana-Colors aren't bad TVs once you fix all the bad soldering and replace some bad small electrolytics. They also used a damper tube that tended to fail and take out the HOT. Check for bad soldering on the plate caps to the HOT and damper. Mine were both badly soldered.
Old 12-29-2003, 10:52 AM
polaraman's Avatar
<--1956 300B
The square thing is a button for the Color Sentry. That chroma color II set is a tank!! it weighs 50 pounds. Got it for $10 at a thrift store.
Pana-color set works real well. I have yet to take off the back to check it out.
polaraman
