Old 08-22-2007, 11:18 PM
I used to love those Sylvania/Philco/Magnavox/GE (made by Panasonic) VCRs from the 80's. That was back when companies names were plastered all over high quality products they didn't make.
Come to think of it, my Dad bought a Magnavox (mfg. by Panasonic) VCR in '85 or '86. It cost several hundred $$ then; but, it lasted for years. Much better quality than anything now. The only drawback to that particular model is that it did not have a cable ready tuner. It had the older varactor tuner with a thumbwheel for fine tuning each channel. I would snatch up one of those VCR's from that vintage in a second if I could find a working one or one in repairable condition.
Old 08-23-2007, 12:24 PM
Yes. When I used to work for RCA in the 80's, we said that "RCA" stood for "Relabeling Corporation of America"...
RCA VCRs were made by a couple of the big Japanese companies.
Old 08-23-2007, 12:37 PM
I think Hitachi was one of them.
Old 08-23-2007, 08:56 PM
waltchan waltchan is offline
They made VCRs for RCA in this particular order from the earliest to the latest:
Panasonic, Hitachi, Samsung, Panasonic (again), Daewoo, and, finally today, Changhong.
Old 08-22-2007, 10:39 PM
lotusstp's Avatar
lotusstp lotusstp is offline
AK Subscriber
Shazam! I remember when Philco started showing up... though I think that was shopped to the remaining Mom & Pop retailers that were still in business, back in the day, so that they could have an "exclusive" line that the Big Box retailers didn't carry. Nowadays it's brands like Polaroid, AKAI & Sansui that are out there confusing Baby Boomers. Hey, even a venerable marque like KLH is used to hawk a wide variety of products (Boomboxes, portable CD players, etcetera).
My mind is like a truck stop... I never know what's going to pull in...
http://www.scorgies.com/blog
Old 08-23-2007, 12:41 AM
Originally Posted by radiotvnut View Post
Well, it finally happened! Someone gave me one of those ultra modern flat LCD TV's that's less than one year old. It's a Sylvania (Funai) 20" model SSL2006. Needless to say, it does not work. The owners said it would play a few seconds and then shut off. By the time I got it; it shuts down instantly at turn on. I can unplug the lamp power supply PCB and the TV stays on with sound. I did find a leaky 220 uF cap so I replaced it and cleaned up the mess. Still no change. From what I've read on the net; these are disposable TV's and parts are not available. If anyone by chance has had luck fixing one of these pieces of crap; I'd love to hear from you. If not; lets all think of some "creative" things to do with it before I let someone use it for target practice. After the ordeal with this piece of junk; I turned the 31 year old Zenith Chromacolor II on to make sure it still works. Of course, it worked!! I gain more and more respect everyday for those older sets! No LCD for me! If it ain't CRT; SEND IT BACK!!
Oh come on. You are comparing with a Funai product versus an old Zenith product. You are comparing apples and oranges. We all know Funai sucks. That's a lame comparison. You should try comparing your Zenith with a Panasonic LCD TV. Now you know that a Panasonic LCD TV rarely dies.
Old 08-23-2007, 12:55 AM
Well, I did see the inside of a late model 36" Panasonic CRT flat screen and it appeared to be very well made. Much better built than those Panasonic / Quasar/ GE 25" console sets from the mid '80's. Those things always had bad flyback's, bad CRT's, loose connections, or a combination of the 3. I'd probably consider a Panasonic if I was shopping for a TV. I also think the Sanyo sets are pretty good for the money.
Old 08-23-2007, 01:19 AM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
Found this on the google. The article discusses replacing the backlight on an LCD monitor, but, they are all pretty much the same inside anyway. http://www.inventgeek.com/Projects/shorts/lcdfix.aspx
Old 08-23-2007, 12:29 PM
willyrover's Avatar
willyrover willyrover is offline
Remove the LCD panel and put in a fish tank.
Old 08-23-2007, 12:39 PM
I've actually given away some empty console TV cabinets for that purpose. Don't worry, it was nothing of collector interest. Just late '80's and '90 stuff. I'd never subject a "real TV" to such abuse.
Old 08-26-2007, 01:08 AM
fsjonsey's Avatar
If that panel were small enough, I'd just remove the backlight, peel off the backing, and place the LCD panel on an overhead projector. Behold, a Cheap, HD capable LCD projector.
Old 08-26-2007, 08:03 AM
Well, you could always do the Monty Python "Dead Parrot" sketch-"That Parrot wouldn't "Voom" if you ran a million volts thru it..." I bet a million volts would make THAT thing go "Voom" pretty damn well... <grin>
