Old 07-29-2015, 03:27 AM
Nice to see your progress.
Old 08-02-2015, 05:55 PM
Could be going south, but I'd make sure all the horizontal adjustments, B+ voltages, and H output tube voltages/currents/waveforms are right first.
Old 08-02-2015, 06:19 PM
Well if you have a replacement then swapping it in to see if that fixes it isn't all that hard, but first, have you swapped the 1B3 Rectifier yet?
Old 08-02-2015, 07:27 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
Yes, uve tried three different 1b3 tubes s and no change.
Old 08-04-2015, 10:13 PM
Did you check or replace the doorknob cap? That can load voltage down if leaking
Old 08-05-2015, 11:02 AM
I did a continuity check to see if shorted, but nothing. I don't have another to sub in to see if it's lesky. I believe it's the common 500mmf Orange cap.b I tried the set with it disconnected and no difference. Do you think that's it? Where can I find another?
Old 08-07-2015, 10:11 PM
Not sure I had high voltage taken away from doorknobs but I think if disconnected it would work if it was shorter. Try the fly replacement
Old 08-07-2015, 10:14 PM
Ok thanks. I may pull out my b-k tv analyst and give that a whirl too. I'll also try replacing the flyback!
Old 08-30-2015, 09:43 PM
So I finally got around to working on the cabinet some more. I grain filled the veneer and replaced some missing trim pieces. I applied some red mahogany stain and some mohawk brown mahogany toner. I ran out of toner and would like to apply an even coat over the entire case to give it a rich look. This is it so far...
Old 08-31-2015, 12:13 AM
It looks good!
Old 09-04-2015, 09:40 PM
Ok, so the cabinet is now finished. I'll wax it and polish it in a week or so. Now back to the chassis....
Old 09-05-2015, 07:52 AM
Front view.
Old 09-05-2015, 07:39 PM
decojoe67's Avatar
Nice job! I prefer a finish a little darker and richer over lighter.
Old 09-07-2015, 07:10 AM
Question
The originally finish was darker, just like how I did it. I try to get every set as close as I can to the original colors.
Old 09-18-2015, 09:39 PM
damen's Avatar
damen damen is offline
Originally Posted by Radiotronman View Post
Front view.
Looks Great!!
