Old 12-29-2004, 02:23 PM
mg196's Avatar
mg196 mg196 is offline
Johnny Thunders - LAMF
I use Bean-O. An excellent degasser indeed!
Old 12-29-2004, 04:12 PM
I rode on a ferry once that had 25" color tv sets. When they turned the tv on, at the dock, the picture was fine, but man, as that boat moved the color went all over the place. Kinda neat. Noticed same thing on some older (crt-type) monitors on an airplane.
My mother has a mid-90s RCA console that she bought at a freight salvage. There is a smear in the color in one corner that has never gone away, not near the speaker or anything like that. I suspect the mask was damaged in transit-the only other damage was a chip in the front of the cabinet. I have a good degaussing coil and would try it out but she has never said anything about it.
Old 12-29-2004, 10:19 PM
AgentWinchester's Avatar
AgentWinchester AgentWinchester is offline
Batteries not included
i saw a soldering gun at the pawn shop the other day-i'll check it out. I'm not about to fork over $40 for a soldering gun. My mother has a aquaintence who runs a tv repir shop, did a vertical circuit rebuild on our big toshiba, i'll see what he charges compared to the price of a coil/gun....Maybe a soldering gun might be a good investment anyhow...
AgentWinchester
Old 01-04-2005, 10:19 PM
Whirled One's Avatar
Whirled One Whirled One is offline
[Sorry 'bout the late reply; I'm just catching up on posts after having been away from the forum for a bit...]
While I can't find or remember the book I saw this in, a few months ago I was flipping through an old TV repair book and it described a simple method for constructing your own color CRT degaussing coil. Unless I'm hallucinating, the instructions were basically:
- Get some ordinary 18 gauge insulated wire (single conductor, type and gauge not critical)
- Coil it up into a ring about 12 inches in diameter (I don't remember the number of turns you were supposed to make, probably something like 20 or so)
- Wrap electrical tape tightly around the loop of wire you just made to keep the coil turns held tightly together
- Strip both ends of the wire and connect them directly to an AC line cord.
...and that's it!
At first, this idea seemed a bit too simple (and perhaps unsafe) -- would a simple coil like that generate enough inductive resistance to prevent it from looking like a short circuit? ...but come to think of it, that's probably pretty much how a commercially-produced degaussing coil is made anyway. Any thoughts? Am I forgetting something important here? Would this be a practical servicing tool or a death trap? [...Then again, I think this might have been something I saw in a TAB book... ]
Old 01-04-2005, 10:41 PM
The construction is generally as you describe, but you should not guess at the gauge of the wire or the total length - it is mainly the resistance thar limits the current, not the inductance. It WILL get warm and eventually hot after only a little while. Commercial units usually have a "hold to operate" switch. We had one with a shorted switch once, and it's a good thing it was lying on a fireproof bench. Of course, if there's no switch, you would turn it off by unplugging, which you are unlikely to forget (I hope!). So, if you find the article and follow the numbers, it should work fine.
Old 01-05-2005, 10:06 AM
I tried salvaging the coil out of a later model rectangular set once, just hooked it to AC. It took about 5-10 seconds to start smoking. I guess the commerical coils are wound on a form, maybe a steel ring? From holding it, it seems so.
Old 01-05-2005, 10:29 AM
dewickt's Avatar
dewickt dewickt is offline
Will fix about Anything
Made one many years ago when I worked for Phillips, memory is that it was 400 turns of #22, it could rattle the shadow mask and got warm after 30 seconds, could demag any tube !!
Terry WB4NHB
DeWick Repairs (retired)
www.mcintoshaudio.com
Old 01-06-2005, 09:17 AM
kc8adu's Avatar
kc8adu kc8adu is offline
hit the yard sales and flea markets.
i just got a weller 100/140 gun in good shape for a buck at olive road flea.
email for more info
Old 01-06-2005, 04:47 PM
outlawmws's Avatar
outlawmws outlawmws is offline
On the Run
OK enoght messing with half measures and guesses. here are 2 sites on hoew to build a de-gauser. I like the first one, but whatever floats your boat.
Site 1
site 2
- Outlaw
Main: 9090DB, Snell Type EIII's, Marantz 6100, TEAC PD-D2500
LR: Motorola tubes, EL84 outputs, , Dual 1019 TT, Sony CDP-CE105, Wharfedale Sapphire SP-89's and a 15" GV center in an infinite baffle
Home Office: Sansui 6060, Sony CDP-C305, Original Advents
Old 01-06-2005, 08:40 PM
glen65's Avatar
glen65 glen65 is offline
Member
I pulled this from an old 25 inch console 20 years ago.
I dont have a light bulb in series with it. It
seems to stay cool long enough for me
to get the job done and the strongest of any
I have ever used.
