Old 10-12-2006, 09:06 PM
I have several sets which were dead on arrival and the switch was to blame. Probably helped to get them cheap/free. My CTC-12 was one example; I suspect that was what retired it. Replacing the switch was no easy task-for one, somebody had glued the knob on; secondly, it uses a very long extension. I finally found something that worked. My Zenith 25MC30 roundie also had a dead switch. Easy to bypass on those sets as there is a plug on the chassis that you can jumper. To save the switches, one trick is to leave the switch in the on position and use a switched outlet. If you've ever taken one of those switches apart you know that there sure isn't much to them. A wonder some of them last as long as they do.
