Old 09-26-2006, 07:01 PM
JCFitz JCFitz is offline
Unfortunately I think he's got a bad yoke. I hadn't seen a bad vertical section of the yoke for 10 years but I got one in today.Mine was a Magnavox 27" chassis 27F800. Looked identical to the one in the picture that was posted. I took loose one of the vertical windings at the yoke terminal.One section was completely open. The good section measures 14 ohms therefore it would measure 7 ohms if the yoke was good. Luckily it's a removeable yoke. I have a similar yoke from a 27" Magnavox with different terminals. I'm gonna try to save the set with that yoke.
Old 09-26-2006, 07:07 PM
If you can find another yoke, you could try to replace it. The hard part will be finding a compatible yoke to replace it with. The yoke has to match both the electronics and the CRT.
I have removed bonded yokes before so I could reuse the CRT in a different set. It's not that hard to do if you're careful. You have to disassemble the yoke from around the CRT neck one layer at a time.
