Old 07-25-2006, 07:41 PM
holmesuser01's Avatar
Question What To Use Since Channel Master SHIELD is NLA..
I just used up the last of the last can I had of the old Channel Master contact cleaner called SHIELD that contained silicone. It is the best Ive used to clean noisy pots, switches, etc. Can you guys recommend anything that is as good or better than Shield was?
The last squirt went into the volume control on my CTC-10C! Smooth and quiet again. Thats why Im asking here in this forum. Any ideas?
Bruce
Old 07-26-2006, 03:05 AM
dr.ido's Avatar
dr.ido dr.ido is offline
I use CRC switch cleaner (product code 2001), which is a contact cleaner with lubricant. Avoid CRC "lectraclean". It comes in a similar looking can, but does not have lubricant in it and can make things worse.
Old 08-01-2006, 08:18 PM
Thanks. I've got a couple of cans of 2001 coming... Will let you know...
Old 08-02-2006, 06:51 PM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
I agree
In all the time I was in consumer electronics, I never found anything that had the long-lasting effects that shield did.
[IMG]
