Old 09-22-2003, 09:16 AM
Marlin Mackley Marlin Mackley is offline
Let's see your photos of mechanical tv's.
Hello folks, this new section of AK forum is devoted to mechanical televisions, and this thread will be the spot for "bragin' pictures". Of course you are welcome to start subject specific threads as well. Please bear with me as I am new to moderating these things!
Thanks!
Marlin Mackley
Old 09-22-2003, 10:15 AM
Rob Rob is offline
Banned
Sequential color Eidophor
The color system that was championed by CBS in the early 50's and that is still used in some industrial and scientific applications because it can use a single B&W camera and phase distortion in the broadcast link does not distort the color reproduction (NASA uses this type of camera on its spacecraft probes) was employed by Eidophor to produce color in its single light-valve projectors. I have several of their 1970's vintage model 5181 that came out of a ship's wheelhouse simulator at the Merchant Marine Academy, Long Island, NY. These projectors use a rotating dichroic filter wheel in the intense light path from the xenon arc lamp on its way to the light valve. Solid state electronics regulate the speed and phase of this wheel and also control video gain and pedestal for each color field. I have had one of my projectors working in the 441 line / 180 field video format on the special color bar and test pattern generator which I acquired with the lot purchase of these machines.
Old 09-22-2003, 10:17 AM
Rob Rob is offline
Banned
Here is a picture of the ship's bridge I spoke of in the simulator with the computer generated "CBS" color visible through the wheel house windows.
Old 09-22-2003, 01:56 PM
House de Kris's Avatar
House de Kris House de Kris is offline
Loud-n-Deep
Mechanical TV
Does this one count?
Old 09-22-2003, 03:18 PM
Rob Rob is offline
Banned
...and its fully programmable too!
See Marlin, this is the kind of stuff you will have to learn to tolerate as a good moderator.
Old 09-22-2003, 05:06 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
simulator photo
I remember those old ship radars with the round crt's. We had one of those on a T2 tanker I used to work on. They don't do near as much as today's radars, but seemed to last forever.
Charlie Trahan
Old 09-22-2003, 06:31 PM
etch a sketch
Dear: House de Kris
I think the resolution is too high, ain't it??
Charlie: I believe those early radar crts used a mechanical scan in so far as they rotated the single direction yoke around the neck.
Rob: Hey I am easy to get along with!
Old 09-11-2006, 03:09 PM
This thread disappeared a couple of years ago, but is still linked to threads I have started, so I posted this just to see what happens.
Marlin
Marlin H. Mackley
www.studio4-17.com
Old 09-11-2006, 05:31 PM
cbenham's Avatar
cbenham cbenham is offline
CBS Field Sequential color Eidephor Theater Television
Marlin
I have two .PDFs on a piece on the Field Sequential Color Eidephor System CBS and Twentieth Century Fox developed in the early 1950s for theater television.
Don't know how to add it to this post since there is no 'attach' button to click on...
Can somebody tell me how to do it? Each one is about 860K.
Regards,
Cliff
Old 09-11-2006, 05:59 PM
cbenham's Avatar
My Electro-Mechanical Color TV built from scratch
About 10 years ago I wanted to build a color wheel TV. I had pieces of an old Col-R-Tel unit but not enough to make a system. I also wanted to make something that would look really good with lots of resolution and less flicker than the Col-R-Tel, so I have worked on this project off and on, revising and improving it to the point where it now runs 640 X 480 @ 90 progressive frames per second [30 RBG color pictures per second] and has subjectively about the same amount of flicker as a PAL TV set. It is still a work in progress and I would really like to increase the vertical rate to 120 or 144 or maybe 180 frames per second. This gets difficult, but not for the reasons you might first think. It's not the wheel or the motor or the video, it's the monitor.
I can't find a nine inch monitor that will operate at this high a display rate.
I can spin the wheel fast enough and make a video signal that fast but can't find a 9 inch CRT monitor that will diosplay it.
I will probably have to build another set with a larger PC color monitor [with it's RGB inputs all tied together to make a monochrome picture] but that also means building a large 36 inch diameter color wheel for it as well. That will be more fun anyway.
Attached is a photo of the present 9 inch wheel set from the top rear.
Cliff
Old 09-11-2006, 07:17 PM
cbenham's Avatar
[QUOTE=cbenham]I have two .PDFs on a piece on the Field Sequential Color Eidephor System CBS and Twentieth Century Fox developed in the early 1950s for theater television.
Here's the first one...
Old 09-11-2006, 07:19 PM
cbenham's Avatar
Field Sequential Color Eidephor page 2
Here's page 2 of the color eidephor piece
Old 09-11-2006, 10:11 PM
Tom_Ryan's Avatar
Tom_Ryan Tom_Ryan is offline
Page 2?
Old 09-12-2006, 02:23 AM
David Roper's Avatar
console lover
When I think mechanical TV, I think of, like, Western Visionettes.
That fits better with the premise of the Early Black & White forum...well...black & dull orange.
tvontheporch.com
Old 09-12-2006, 04:22 AM
Tom_Ryan's Avatar
Cliff, thanks for the Ediphor article. Here'e an interesting link that is similar to your PDF but has more details and some intereseting pictures of the Ediphor Theatre Television System.
http://www.experimentaltvcenter.org/...3?id=16&page=1
Gretag manufactured a modern version HDTV capable based on the color dot sequential system replacing the original CBS field sequential method.
Another system that owes much to Ediphor was the GE Talaria system
http://www.hi-def.com/12K.html
Tom
