It says on the remote that came with the tv that it takes Type (J) 6V not sure if I have ever seen a battery like that??? just thought they all took either AA or AAA
On the TV keyboard, you can put channels in memory by keying the channel and pressing ENTER on the TV keyboard. Note that they will not stay in "favorite channel" memory if you key them in by the remote. And to get rid of ones you don't want, go to that channel and push SKIP. Most Cable TV signals around here are "STD" setting, but you can play with that switch and see which position gets the most channels for you. The AFC is also an experiment. First set it as FIXED, and see if some channels have no color or no sound, or are out of tune. If so, go to SEARCH AFT and see if that's better. The FIXED position makes the channels change much quicker though, if it works in your neighborhood. Charles Last edited by Kaye-Halbert TV; 05-27-2006 at 01:25 PM. |
AFC fixed/search option
"AFC fixed/search" in Zenith TVs of 1980s-'90s vintage has to do with the tuner AFC system, not the channel scan, IIRC. The search option is used if you have a video game or some other external device which does not work or works poorly with the option set to fixed. The search feature causes the tuner to search for an external unit's true output frequency, which is very often different from a broadcast or cable signal. For use with regular broadcast TV or cable, I'd leave the fixed/search option set to "fixed" and forget about it. Zenith used this option on many of its cable-ready sets of this vintage (it is on an OSD submenu on some sets, like the Sentry 2 series). The channel search is done by locating AUTO CH. SEARCH on the OSD setup menu and pressing either ADJUST key to start. The tuner will then search for and store in memory all active channels in your area or on your cable system.
Hope this helps. Kind regards,
