Old 03-31-2006, 01:34 PM
Tony V's Avatar
Tony V Tony V is offline
Hi Jordan,
Thanks for the advice but i had already performed the static and dynamic convergence with my cross hatch generator. The problem is that the red/green adjustments for the left and right parts of the screen dont function at all so theres no way in its current state to adjust for it either horizontal or vertical. The blue adjustments for the sides work fine. The top, bottom and center converged perfect and the yoke and convergence magnets are in proper position on neck of the picture tube. Purity and white balance are fine also. I suspect the convergence board is faulty and if so i will need one as i have no Zenith parts here. I also remember someone having similar problem but it was because they lost voltage somewhere. I just want to see if you guys had a good place for me to start first. I dont have a schematic for this set by the way. I understand there will be some misconvergence with the older delta's but the error on the sides is close to a half inch in its effort to make a white line...mainly with the horizontal part of the adjustment. The misconvergence is mainly noticed on the first three inches of both sides of the screen and the lines are green, blue and then red with an eighth inch gap between them almost. I'll try to post a picture of it if this is still confusing to everybody.
Thanks,
Tony
