Old 03-23-2006, 01:54 AM
Jonathan Jonathan is offline
AK Member
Well, I finally got the rest of the electrolytic capacitors I needed. All electrolytic capacitors are fully replaced. Upon reassembling the HV section I see the top lead is broken off. I tried to solder it but it's broken right at the base of the glass nipple. These tubes are quite ratre, aren't they? I suppose I could use a dremel and grind down the nipple and possibly I might be able to attach it. Thankfully, tubesandmore has them. Anyone have the datasheet to these tubes?
Thanks.
Jonathan
