Old 03-20-2006, 02:23 AM
kx250rider's Avatar
REAL TVs have TUBES!
The VTX-1100 has CATV up to ch 80, and as you mentioned the VTX-1000 is only to 36. Also, the 1100 has on screen channel display. Only down side to the 1100 is that it has no 0-to-9 buttons inside the door like the 1000 has. If your control door isn't busted, that means you have common sense that others don't always seem to have. The way they get busted is that when you go to lift the KX, your Right knee goes right through the door . I usually pop the door off safely.
And you're not kidding about the weight of the 2501... 126 pounds!
Charles
