Old 07-07-2003, 10:32 PM
Rob Rob is offline
Banned
Doug,
Regarding the poor red purity. Have you done the 'slide the yoke' forward purity adjustment, full size raster with the green and blue guns cut off?
Regarding 'zapping'. Don't do it if you can avoid it. Sometimes zapping makes it irreversibly worse. I've had good luck bringing sleeping cathodes back to life in color tubes with elevated filament voltage at 7-8 volts for overnight. The 21" round tubes usually fully recover this way after measuring almost dead from sitting 30 years. I guess you have to burn the cobwebs outa there.
Also, don't forget to examine the focus pin on the CRT and the associated contact in the gun socket. The corona around here can cause ozone that is very corrosive. This can lead to poor contact. I have a Zenith with 21FJP22 with a bad case of pin/socket corrosion...and a focus problem.
Rob
