#31
It was pre-war. I found this info on the Sola web site: Joseph G. Sola, founder of Sola electric was both a far-sighted inventor and successful business man. Internationally recognized as the pioneer of transformer magnetics technology, his inventions and subsequent refinements of other electrical equipment were considered revolutionary by the electrical industry. Sola's first transformers for furnace ignition systems and neon lighting, based on his unique application of ferroresonant principals, led in 1938 to his invention of the constant voltage transformer. This timely discovery was eagerly accepted by prime military contractors during World War II, and established Sola as a world leader in voltage regulation. Sola was awarded 55 U.S. Patents during his lifetime, including five each for constant voltage transformers, Solatrons, electronic power supplies and 19 for high-intensity discharge lighting ballasts. |
#32
$2k
Wow, almost $2000 for a set with a bad CRT and in need of refinishing
#33
Crosle & DuMont 30" Sets
Hawkeye cannot rebuild a 30" CRT, it will not fit in their CRT lathe. I am pretty sure the 30" Crosley was made by Crosley, not DuMont. The HV supply is similar to other Crosley sets of the seame vintage.
DuMont also made a scaled back version of the Royal Soverign, model RA-119B1 and RA-119B2 (UHF). My set does not have the UHF option. This version has a turret tuner, and flyback power supply, and a very conventional chassis layout.
John Folsom |
#34
Marlin,
Hope you get the Crosley, and if you are lucky, your CRT will be in better shape than mine. While mine is still under vacuum, there is no emission left.
John Folsom |
#35
Back around 1964 , In a Salvation Army store, I remember seing a huge GE console that must have had a 30 inch CRT. It was easily the largest set that I'd set eyes on . The knobs were located on the right hand side of the CRT , top to bottom, on the front of the cabinet. I believe it had the pencil case door located midway between the knob sets.
It was working and had a very good picture. Being that GE made a 30bp4 for replacement, I have always wondered if that set used it. I've never encountered another GE like it. Probably very expensive, though. Anyone else ever seen one, or better yet, have one?
Last edited by pallophotophone; 03-01-2006 at 06:50 PM. Reason: I'm New At This - Should this be a new thread? Thanks ! |
#36
This may have been a 27" b/w set...I have one that is a Magnavox.
#37
According to that book I have "Behind The Tube", Dumont made a replacement run of 30BP4s in '51, but still was having problems w/them, so they offered a 27" retrofit kit, & apparently used an aluminised tube that took care of the problems they had on the 30" size. -Sandy G.
Benevolent Despot |
#38
"We will bury you! Your children will be spoon-fed Socialism! Your grandchildren will live under Communism!" -- Nikita Kruschev Recent history suggests that Kruschev's threat from the 1950s has very nearly become our present-day reality. As my son observed in his high school English class during study of Orwell's near-prophetic 1984, "Orwell only missed by about 20 years." Tim said that in 2004, and he was RIGHT! Regarding the Sola transformers that Dumont used in the RA-119 and other models, I wonder how much "pull" we AK members might have as a group toward convincing Sola/Hevi-Duty to reissue one or more of those old transformer designs for the new-construction tube audio market. A reissue of those transformers would be excellent power transformers for 100W monoblock or 50W stereo amps. Perhaps, with enough suggestions and potential demand, Sola might even consider producing a version with doubled ratings for 200W monoblocks or 100W stereo. |
#39
Back to the sub-topic of those CV transformers, another AK member has pointed me in the direction of a vendor which might be a source for new plate & filament supply CV transformers like Dumont used in many models (of which the RA-119 was one) which might be close matches for replacement use and/or good choices for powering new tube audio amp designs, particularly custom-installation "dream systems" equivalent to theater sound systems. Since the CV transformers produce an audible mechanical hum during operation, purists might prefer to have any amp powered by such a transformer mounted outside the listening room, much like the massive Western Electric amps used in theaters had been rack-mounted in theaters' projection rooms. Any 60Hz power transformer rated above 0.5KVA, however, will likely produce a soft but audible mechanical hum, as it is difficult to prevent the strong magnetic fields which such transformers produce from producing some mechanical vibration at the line frequency and/or harmonics thereof. Such a massive transformer of any type might even couple its vibration to the amp's chassis via its mounting, causing the vibrations to be amplified a bit by the chassis structure just as the bodies of acoustic string instruments (violin, guitar, etc) function as mechanical amplifiers. About the Dumont and other 30" sets, I wonder how many were fitted with the subsequent 27" rectangular tube retrofit due to reliability issues with the 30BP4. |
#41
Just a friendly reminder, Politics are not allowed on AK not even in the Off Topic Forums.
This hasn't gotten out of hand so I haven't edited anything but please stick to discussing TV collecting, repairing, etc... Thanks, Eric |
#43
The Sola transformers were used in solid state Zenith, Magnavox, Quasar, and Panasonic sets of the 70's/early 80's.
I don't know about use for HI-FI audio as the transformer produces a squarewave which is harder to filter out and may introduce more noise. Probably an electronically regulatated power supply such as using a 6080 tube would be better for that application. |
#44
In my 2x50W EL34 amp, I use a pair of 6080/6AS7 tubes controlled by a 6AU6 with its cathode voltage held constant by a 150V 5W Zener diode. The input to the regulator is the rectified and filtered output of a Sola CV transformer. |
#45
Speaking of 30" sets, here's a mystery that I've wondered about from time to time. Perhaps someone here can identify what this TV could have been..?
Back in the mid/late 80's, I came across a weird early-50's-era-looking antique console TV at a big antique show/flea market. All I remember is that it was *really* big, and had a *huge* unmasked round CRT (just a big round frame around it). Despite the 'porthole' look, I am pretty sure it was not a Zenith-- at the time, I didn't think to see what brand it was (or I forgot), but I recall that the styling didn't seem very Zenith-like. I seem to remember that the back cover of the set was made of metal and full of small round ventilation holes, but I could be mistaken. I don't know for sure if it was a 30" set, but it was *big*, and defnitely bigger than a 19" B&W round tube. Back at the time I saw it, I might not have been able to correctly identify if it was a color 21" set, but I've never heard of a 'porthole'-style color roundie, and besides, the screen looked bigger than that, so I'm thinking it was likely a 30" B&W (did anyone ever make, say, a 27" or 24" B&W round CRT..?) Anyway, I never saw another set like that again. However, sometime perhaps about 10 years ago, I happened to be flipping channels and stumbled on _Mister Rogers Neighborhood_. At that moment, Fred Rogers was just leaving to go to someone's house for some purpose that I don't recall. When the scene switched to that neighbor's house, however, a great big round-screen TV was briefly visible in the living room, and I immediately made me think it was the same model as that one I had seen at the antique show. Anyone else here ever see an odd looking big 'porthole'-style TV like this? Or am I just imagining the whole thing..?
