Old 02-21-2006, 11:45 AM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
Professional color television monitor from 1970
Before two weeks I have bought an old studio television monitor for EUR 5.00. It is a Class 1 monitor and it was made by the Fernseh G.m.b.H. in 1970. Tubes were used in the horizontal output unit (PL509, PY500, GY501 as high voltage rectifier and PD500 as shunt regulator. The other parts are solid state. It is the first time I got a professional television monitor. Inputs are: R, G, B, Y, Sync and composite video. The composite video unit has a switch for PAL to NTSC.
One PY 500 was missing. After replacing it, I found that the PL509 is bad. After replacing this, I got high voltage, but no picture. There is a negative voltage at the first grid of the crt. It is a 1842P22. Now I am looking for the schematics. But it is very difficult.
Meanwhile I got the luminance channel working, but no sync:
http://bs.cyty.com/menschen/e-etzold...firstLight.JPG
With a video-test-signalgenerator I got a steady picture. And with a DVD video signal at the input of the video-test-signalgenerator I got a moving television picture.
The composite video unit is not working. Without schematics it is difficult to get this monitor working. But it is a very nice peace of early professional color television technology. Does somebody here has informations about professional video standards in the late 1960's or 1970's?
Old 02-21-2006, 01:00 PM
Wow....that bad boy is REALLY something, especially compared to the rat's nest you usually see inside a TV...-Sandy G.
Old 02-21-2006, 01:07 PM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
THat is absolutely awesome. Probably one of the best built monitors at a glance. The modular design rocks. I would never have thought a hybrid setup would be used in the professional world. perhaps the transistors were not reliable enough to use as the HO and HV yet.
Very cool.
Jordan
Old 02-21-2006, 01:39 PM
yagosaga's Avatar
VK Member
This monitor was developed and designed in 1965, two years before color television started in Germany. At that time only the Telefunken brand had developed color television technology. Compare the flyback of the monitor with the first commercial color tv set:
http://bs.cyty.com/menschen/e-etzold...ilpalcolor.jpg
It is the same. And here, the PAL delay line unit
http://bs.cyty.com/menschen/e-etzold...ffs1967pal.JPG
is the same as used in the professional monitor.
Old 02-21-2006, 06:11 PM
captainmoody's Avatar
captainmoody captainmoody is offline
The deflection yoke assembly looks suspiciously like an RCA unit...
Old 02-21-2006, 06:37 PM
What kind of shape is the CRT in? Looks pretty good, but of course, that doesn't mean anything. Is it a std CRT, or a special one ?-Sandy G.
Old 02-22-2006, 07:54 AM
yagosaga's Avatar
VK Member
I think it is an RCA type. The developer of this monitor told me, that they imported RCA picture tubes for this monitor. The Germans were not able to produce professional color picture tubes in these days.
It is no standard CRT but a special one. The screen surface is somehow rawer than usual. The phosphor dots are much smaller than those of standard CRT's. And the red phosphor is deeper-colored than in contemporary standard tubes.
Old 02-22-2006, 08:48 AM
wiseguy wiseguy is offline
Hey yagosaga.
you may have to loop the composite video thru the sync input in order for the composite video to work,I have a couple of old broadcast monitors that work like that,and require ext sync even for the composite video,those usually were fed sync or blackburst from the studio's house system, those monitors are heavy..!
I had an RCA version that i could not carry myself..I wish i would have kept it but it had been on and cooking 24hrs in a studio for like 18yrs.
Old 02-23-2006, 01:56 AM
yagosaga's Avatar
VK Member
Originally Posted by wiseguy
you may have to loop the composite video thru the sync input in order for the composite video to work.
I have used several video input sources. With terestrial tv broadcasting, it didn't work. The sync didn't lock in and the picture is somehow blurry. With the video test signalgenerator, it worked. And now I have found that it works with my second DVD player. Sometimes iif the picture is darker, the synchronisation did not lock in. Perhaps the monitor needs a stronger video input signal than provided by today's video sources. I am waiting to get the schematics. The composite video input still does not work. I use RGB with sync input (loop).
Old 02-26-2006, 09:29 AM
yagosaga's Avatar
VK Member
Hey yagosaga.
Hey wiseguy,
the monitor is working now with an excellent picture and beautiful colors. The CRT has the original EBU posphors:
http://bs.cyty.com/menschen/e-etzold...h/MC47_3BA.htm
The photos can't reproduce the amazing picture in original. And the solution was quite simple. I have followed the input signal with a meter to find the path of it in the circuits. In this way I found that the composite video module has an RGB and sync output on the back of the monitor. I have noticed the RGB output before but thought that this is for external sources.
It was obviously, but I didn't recognize the function of it. I have only to loop the RGB output of the composite video module thru the RGB input of the monitor. And then it works. It is so simple
Old 02-26-2006, 06:06 PM
Beautiful!
Old 02-26-2006, 06:16 PM
That is a GREAT picture ! Excellent work ! You REALLY have something to be proud of- Between that & yr CTC-5, I'd say you have one of the finest TV collections in Germany...What OTHER goodies do you have?-Sandy G.
Old 02-26-2006, 10:02 PM
Outstanding! Isn't it a joy to work on something that is built this well?
Old 02-27-2006, 01:16 AM
You don't see many old professional monitors. Most seem to be used heavily and then scrapped.
Old 02-27-2006, 02:59 AM
yagosaga's Avatar
VK Member
Hi AK'er, thank you for your numerous comments and acknowledgments.
This monitor belonged to the technical university here in Brunswick, and it was property of the government. I think that they didn't run this monitor very often at the university. There is not much dust in it, and the picture tube seems still very strong. I will test it with the crt meter today.
This is my first professional monitor I had on the bench. I am still impressed about this elaborated and servicefriendly circuits. This professional technology shows what is really possible. The commercial sets I have seen before are a compromise between quality and costs. When I find time in the next weeks I will write a documentation about it for the web with an English translation.
Look at this page
http://bs.cyty.com/menschen/e-etzold/archiv/TV/tv.htm
and click "Start". All listed sets with an an asterisk are part of my collection. But I have reached a limit, there is no more space in the house, and in summer we get our third child. I have to put some tv sets on the attic of my parents and will keep here only the most interesting sets.
P.S.: I have just telephoned with the engineer, who created the deflection units of this monitor. He told me, that 1500 monitors were built in 1965-1970. Each of them costs 18,000.00 Deutschmarks (for example, the Volkswagen 1300, a car, costs 5,150.00 Deutschmarks in these days). I have an exemplar with an NTSC module.
These monitors were exported in the whole world. (The SECAM models should reproduce better SECAM than the French aequivalents ;-)
Yesterday he saw some monitors of them still working in a Iranian nuclear power station in the evening news. I found a video of it still on the web and made a screenshot:
http://bs.cyty.com/menschen/e-etzold...MC47inIran.JPG
The black-designed monitors have the SECAM module inside. Incredible, hybrid tube-transistorized monitors are still in use today.
