Old 02-13-2006, 09:46 PM
Adam's Avatar
Adam Adam is offline
I had one of those, the chassis was really damaged and I finally just decided to keep it for parts, and I had gotten a empty cabinet seperately (the one I was trying to give away a while back), I was also missing that 2nd chassis (it is both the audio amp and the power supply). The power supply is unusual it is as if it had 2 seperate supplies, but uses only one trans. then 2 rectifier tubes (not in parallel like the Westinghouse, but comming off 2 seperate coils in the transformer) a 5U4 and a 6X5, the 5U4 section is supposed to output 350v and the 6X5 section 155v, when I was trying to make one I couldn't find a transformer that would work and finally had to use two seperate ones.
