Most Sony's have a pretty complete set of geometry adjustments, even a 21". They will mostly be small pots scattered around the deflection board. Look things like "pin amp", "pin phase" and "keystone", or abbreviations of those names. They function like the controls on a computer monitor. A PVM monitor should have lots and lots of control to play with and should end up with near perfect geometry. A cross hatch generator is a must; don't even start until you have a way to display one. There will be two sets of controls if it supports underscanning, so make sure you adjust the right set. Also, be sure to adjust the geometry after the size and centering because they interact. Most Sonys look a lot better after a little adjustment.
Center convergence is adjusted by the rings on the neck of the CRT and the H Stat control. Edge convergence is adjusted by tilting the yoke. There may be a few pots and coils on the yoke that also affect dynamic convergence.
