Old 01-12-2006, 10:42 PM
Originally Posted by Chad Hauris
Bryan there was probably brittle insulation on the ballast wires.Almost every jukebox we work on that is older than the mid 70's or so has brittle wiring on the ballasts due to heat and we replace them. These are usually simple 2 wire ballasts that you can get at Home Depot or the hardware store for about $5.00 and they have new plastic insulation that is a lot tougher than the old cloth covered wire.
Luckily the sign has 2 lamps with seperate ballasts & one gives off plenty of light. Its a "Diet Like" sign from the 60s. I think I have a spare ballast now, but back when I got this I had less stuff in the junkbox & was even dumber than I am now!
The next time Kim gets to whining about the Samsung whining I'll poke around & see if I can shut it up...
