Old 12-18-2005, 08:21 AM
OvenMaster's Avatar
DTV blows
Originally Posted by Adam
Can you tell from the box if a DVD has the copy protection or not, I would like to avoid picking up anymore of these DVDs if I could.
Some boxes say they have "Quality Protection by Macrovision" on them, but most don't. I'd be very surprised if any commercially produced DVD didn't have protection. This is why DVD Shrink and ImgTool Burn are so popular. The lone exceptions seem to be some public service DVDs and some porn.
Tom
PS: That's a nice El Camino, Adam.
Tom
Old 12-18-2005, 09:14 AM
Lefty's Avatar
Lefty Lefty is offline
AK Member
Well I recently bought my Wife a DVD/VHS recorder that was to allow my wife to convert all her old VHS tapes to DVD so we can save a little storage space around here. It works fine on tapes that don't have Macrovision encoded on them, but we found that only about one out of 10 tapes don't use the Macrovision copy protection. I did some research via goggle and as best I can determine Macrovision is pretty standard on most all VHS AND DVD commerical media regardless if it is maked such or not. That means on DVD disks there is digital copy protection (which seems to be breakable on PCs with the 'right' ripping software) and Macrovision copy protection to prevent making analog copies of DVD disks. To be fair to the new recorder it was clearly marked on the box and the manual that it would not record Macrovision encoded tapes.
Anyway I've ordered but not received a video stabilizer that is suppose to clean up the blanking/retrace pulse in any Macrovision encoded signal. Then I should be able to copy VHS/DVD from a upstream player into the new recorder via it's RCA video/audio input. I'll post the results after I receive the device if any one is interested.
http://www.checkhere22.com/stabilizer.html
Lefty
Lefty:
Cables? I don't got to show you no
stinkin' cables
038° 00' 58.68" -122° 15' 39.54"
134.84 ft
Old 12-18-2005, 10:31 AM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
problem with sync pedistal
when the vcr first came out we had similar problems because the sync pulse generated on the vcr were lower than the old tube sets could handle, try using a video amplifier to boost the video level, the macrovision shouldn't really have any effect. I can still copy any movie on my beta-max.
[IMG]
Old 12-20-2005, 08:08 AM
domfjbrown domfjbrown is offline
AK Member
Macrovision has never worked with Betamax; I think it's something to do with the auto gain recording level for video signals that Beta uses - yet another performance enhancement that VHS conveniently "left out" to give us the Crap-o-vision we know and love.
Speaking of which, my new (to me) Sony widescreen telly seems to have issues with Macrovision-encoded VHS tapes, despite the video being connected directly to the TV by a short (<1m) SCART (AV) cable. Real pain in the arse...
Make your choice, adventurous Stranger;
Strike the bell and bide the danger
Or wonder, till it drives you mad,
What would have followed if you had
Old 12-20-2005, 09:28 AM
madpioneer madpioneer is offline
AK Member
Although Macrovision since it was first used has been a PITA there is ways to get around it. I had some problems backing up some of my Laserdiscs when I tryed recording on my DVD recorder. Sharpness and colors were off. I started to do a little research and found the SIMA Color Corrector 2 did the job for me. It will eliminate any copyguard at this time on VHS, DVD. I tryed to record some of my Mr. Bill DVD's for a good friend and even my older smaller copyguard eliminator left thin yellow lines across the screen. SIMA will take care of that. Yeah it can be a little pricey, but if you are going to do alot of viewing and recording of Macrovision I would strongly suggest it. I dropped $200 locally for one just because I needed the option to take it back in case it didn't work for me or it encountered problems. You can adjust color blue,red,green-sharpness-contrast-tint-brightness. Has s-video & rca in/out can handle 4 inputs and is remote controlled. Its an amazing little unit that has worked for me now for about a year. When I transfer my Looney Tunes the colors are even brighter than the original in some instances. I have tryed those small hideaway types and they work for simple applications but if you require more control the Color Corrector is the way to go. Color Corrector is for VHS only the Color Corrector 2 or II is for DVD/VHS and can handle any Macrovision until blue ray arrives. I have read they will use an updated Macrovision for those. I have no affiliation with SIMA I just know it works and my friends are impressed with my transfers.
Below: SIMA SCC is for VHS only the second pis is SCC 2 for VHS/DVD
Old 12-20-2005, 11:55 AM
Old 12-21-2005, 08:24 AM
Adam's Avatar
Adam Adam is offline
Thanks. Unfortunately, It is not one I have, more one that I want. It used to be my grandfather's. I really like those 59/60 GM full size models.
If I ever stop using my computer as a DVD player, and get a regular one, I might try one off that list too.
