View Poll Results: Your opinion about today's tv's
They are good 0 0%
Some of them are good, some of the are bad 11 34.38%
With a few exception, all are junk 15 46.88%
They all are junk-I don't wanna hear about them! 6 18.75%
Voters: 32. You may not vote on this poll
Old 12-09-2005, 11:07 PM
JCFitz JCFitz is offline
Originally Posted by Adam
I don't really know much about the 91 RCA I mentioned above, I've never looked inside it or one like it. I just know it has never given me any trouble.
I've never had as bad an experience with TVs as all those 90s Sonys though. They all had that tuner trouble, you would be watching the TV and then all of a sudden it would be nothing but snow and static. I had 4 of them, , they all did this.
Those Sonys had a common problem with that but it was an easy fix.Take the tuner of the board and carefully resolder the ground tabs where the shield soldered to the pc board.If they were early 90's they were fairly good sets except for the tuner grounds.They had 2 other problems.Bad connections on the coils in the IF pack and leaky caps on the MTS board which is dirt cheap and commonly available.The CRT and flyback in those sets seem to be much better than the mid 90's and up Sonys.A lot are still going with great pictures.The later ones are more junky.Especially the 32" ones.The worse thing is when 1 gun goes weak they start blanking out the picture.We actually fixed one of the 36" XBR Wegas from 2000 because it was under service contract.The green gun had gotten weak and this particular model shuts down when it can't balance the 3 guns.Sony had a real big problem with the CRTS in certain projection tvs from 2002 and 2003.They're still extending the warranty to 4 years to change all 3 CRTs and some resistors.One of them the filament resistor.They get intermittent shorts causing flicker or 1 gun showing retrace lines or actually going full on causing the set to shut down.A lot of them you can see sparks fly when you tap the neck of the tube.
As for System 3 Zeniths I have an '85 Advanced System 3 that still has a beautiful picture.My uncle has a mid 90's Toshiba projection still going strong.Needed the convergence chips changed about a year ago.Mistsubishi sets in the 80's seemed to be made well.My mom has an '87 projection set still going strong and I saw an '81 model(the one with the flip down mirror and curves screen)still going.They went down the crapper in the 90's.I've worked on a lot of them.The sets still seem to be built well otherwise but they used bad electrolytic capacitors.They leak.By the time the set starts giving problems there are usually 30 or more electrolytic capacitors leaking and must be replaced.My record was 80 capacitors.Also the contamination must be removed from the board and a lot of times eaten traces must be jumpered and other damaged parts sometimes.And the projectors leak coolant fluid on the circuit boards.It's a shame because they give excellent pictures and the CRTs last and last.Mysteriously they still use the same capacitor vendor though I haven't seen the later ones leaking.Did have one with about 20 or more with high esr causing interfence lines in the picture.Hitachi seems to be a well made projection tv.Only the convergence chips fail on most and they keep running.
DLP tvs and Plasmas are a headache.If a driver chip fails on the panel in a Plasma it's not replaceable .The panel has to be replaced.In some cases it's a line or a few lines of different colors running down the screen.If one really shorts out it won't play at all.Dlps have expensive lamps often costing $200 or more that rarely last over a year.And the bearings go bad on the exoensive color wheel too.BTW talk about energy hogs Plasmas use more electricity than an all tube color tv.I've seen 450 watts on the back of one.
