Old 08-13-2005, 09:58 PM
Chad Hauris's Avatar
I may be able to scan you the sams tomorrow. It will be a jpg file hosted on our site so you can download it, then I'll remove them once youve got them to conserve our disk space.
I always put the fuse right first where the power enters the set in the hot lead. That way if anything shorts. filaments, diode, whatever, it blows.
1/2 amp would probably do for a table top radio.
If a set is using ceramic capacitors they are usually still good. You may be able to upgrade your audio quality by replacing any ceramics in the audio circuit with mylar. I'd go ahead and just do those electrolytics while you have the chassis on the bench, even if the old one looks good, just so you don't have hum problems creep up in the next 5-10 yrs.
Chad Hauris
Old 08-14-2005, 01:30 AM
Nolan Woodbury's Avatar
Nolan Woodbury Nolan Woodbury is offline
Shaken, not stirred
Hi Chad,
That'll be great. I'll try to download and save right away.
I think this is an important upgrade, because plugging and unplugging a set seems a major hassle. That's the main concern, correct?
I'm almost positive the H845 uses ceramics. I wonder how many are in the audio circuit? Perhaps just one?
If you can't get to it right away Chad, don't worry about it. Feel free to send me a PM or a email after you upload.
Thanks again Chad, as always!
Old 08-15-2005, 05:29 PM
Nolan, I couldn't find the sams index last night and was time to go home. I know I can find you those sams but I need to find that index. If you can find out what folders those radios are in it will help.
Chad Hauris
