The one in my Silvertone produces good sound, but the radio dial needs recalibrated.
I tried the Zenith on a test speaker. I think it's stuck in mono. Unfortunately, i don't have a print for it. I'll get a rear view of this just to show the speakers.
The world's worst TV restoration site on the entire intranoot and damn proud of it. http://evilfurnaceman.tripod.com/tvsite |
For the past year now, my daily watcher has been a 69 zenith space command set, a twin speaker console. Has 2 6x9's. Not a combo, but it certianly has outstanding sound. Watching a movie is great. Nice deep bass and crisp treble. truly outstanding sound quality for using a "Non HIFI tube", zeniths very own 6Z10! I dont have a combo yet. Id like to have a danish modern zenith combo (with space command of course!).
My '63 Curtis Mathes b&w combo puts out an impressive sound. It has two 12" woofers and four 3-inch tweets/mids. Puts out both good bass and treble. Output is thru two 6BQ5's. Sounds great with radio, records, TV, and a CD player plugged in.
My '66 CM color combo is alright, but not near as good as the '63 model. The '66 CM is running two 8" woofers and two 4" mids driven by two 6BQ5's. It does have a clean sound, but the smaller woofers take away from the bass. The '65 Magnavox combo I brought home last week is definately lacking in the audio. The Astro-Sonic stereo is all solid-state. Sounds like it could possibly use some new output transistors. I think it has 4. I'll probably change those old electrolytics on the cross-over as well. The audio is somewhat garbled. Looks like it has either 10 or 12 inch woofers, and also has a set of horn tweeters. The bass is pretty deep... but garbled. So, between the 3 of mine, the 63 CM sounds best and gets the award. I've been listening to it for 10 years now, and I've always been impressed with it's sound.
Charlie Trahan He who dies with the most toys still dies. |
I do not know about the the audio side of Motorola consoles, but I do know about their B&W portable TVs.
I have both pre-1965 and post 1965 Motorola portables. The quality definitely is much worse on the post 1965 ones. They followed the GE/Philco trend of putting hot(horizontal output, etc) tubes on PC boards, etc after 1965. Before this, they were like Zenith with the metal hand wired chassis. One big fault with all Motorolas that I have ever seen (even the 1950s ones) is that they used the horrible wafer style tuners instead of the much esaier to clean barrel type. |
Why would you change the output transistors? They don't wear out like tubes. Either they work perfectly, or not at all.
Some power transistors are made in sections. If the metalization between sections opens up, the transistor may still function somewhat, but performance will be degraded.
However, I would still check all caps and resistors before changing transistors. |
Sounds like what I am hearing so far is that most every manufacturer had a decent sounding combo except Motorola! (At least late 60's Motorolas)
