Old 02-18-2026, 08:42 PM
Retired Batwings Tech
I will look deeper into this. On my end I'm using all CRT's on the analog side and Dell S-2409 LCD @ 1920x1080-75Hz refresh. Now that you mention it the vertical detail does look like its missing one field on the final.
Going to basically start over from scratch with default settings and see how that works out.
Thanks for the insight.
brett
Old 02-23-2026, 07:42 AM
Okay so the moment everyone (almost no one) has been waiting for; Old-school U-Matic video captures from the early 1990's. Yes I have finally got everything captured and uploaded to YouTube in its native low-def 4:3 glory. Everything is direct from my old U-Matic tapes that were recorded using a JVC CR-4900U portable and captured on the Sony DXC-M3A when it had good tubes, only the night scenes were shot using a DXC-3000 and they look ghastly.
The signal chain starts with my VO-2860A feeding a NOVA 800 full frame TBC and this was run into my Sony DVW-A500 DigiBeta and chop & paste edited running the decks as a master & slave pair with all the signalling SDI then captured using a NewTek Tricaster Broadcast TC-550 which uses a mild hardware mpeg-2 then uploaded to YouTube and watered down even more. No the end video is not 4K or even 1080P but rather a testament to the resiliency of the U-Matic format. This was state-of-the-art before DVD's and I'm sure the critics will have plenty to say, don't expect an apology from me.
The issues I was having earlier were the result of multiple codecs and a timing issue with my one TBC that wasn't apparent as I use all CRT's. A complete recapture and direct upload in the mpeg-2 format eliminated all of this and for a 30-something year old video it doesn't look terrible.
Anyway check it out tell me what you think, flames will be ignored... or laughed at.
https://youtu.be/2HlJLsBXHxQ
Old 02-23-2026, 05:54 PM
redk9258 redk9258 is offline
Looks good to me.
Old 02-23-2026, 06:22 PM
So how this all came about is I got a set of new satacon tubes for the M3A thanks to a friend at a local station and spent an evening setting everything up as best I could with the what I had, Hitachi V-089 vectorscope, V-099 waveform monitor and Sony multi standard monitor with the intent of getting some really good video to put on the Mpls cable access channel-35... that was the intent anyway. I ended up setting the green ped at 0 ire with the red & blue at 7.5 and didn't do a diff check or go over my work, all looked good on the scopes and I went with that. Next day in the car I do a quick auto black balance and everything does what it should and balanced against the green that it assumed was at 7.5 and set the levels accordingly, I didn't know this at the moment and assumed all was well until I did the playback that evening and saw my error and ended up chucking all 6 tapes into a drawer hoping they'd disappear forever... I was pi-- well you get the picture of why everything has a slight green cast.
The night shots were sometime later when I tried out a DXC-3000. I wanted to see what the night sensitivity was like, it was alright but the camera was too sparkly in normal light and edgy with proper lighting so I went back over the M3A and got it right but it ended up on the back burner in favor of a DXC-325/CA-325 package with a deep educational discount of $3500.
I was originally going for an urban documentary using the angles for a more in the moment feel, actually it worked well with the fast clips and motion thirty-some years later.
Old 02-23-2026, 07:16 PM
Old 02-23-2026, 09:13 PM
I might have a few more tapes shot on the M3A using the CR-4900U but the pennies were put away for a betacam and that ended up being an AMPEX branded BVW-35, if I can find them I will put something together.
Old Today, 12:00 AM
DVtyro DVtyro is offline
It does not look bad. But it does not look correct.
U-Matic is an interlaced format. If you upload it as interlaced, Youtube deinterlaces it into 30p. At best, it loses half of the vertical resolution and half of the temporal resolution. At worst, it introduces blended fields. Yours looks rather clean, but the resolution has definitely been lost, there is only one field out of each pair.
The attached picture shows stairstepping on diagonals, a clear sign of the vertical resolution lost. At least there is no ghosting.
You need to deinterlace with a quality "bob" deinterlacer that not only splits fields into frames, but also merges static parts of both fields to increase, nay, to preserve the vertical resolution. QTGMC is the current state of the art among free deinterlacers. Another thing about Youtube is that it honors 60p only for 720p and higher, so you need to upscale to at least 960x720 or even 1440x1080.
TLDR: Deinterlace into 60p, upscale to 1440x1080 and re-upload.
It was state of the art consumer format when it launched. At the time it was accepted by pros, it was barely good enough. It would not satisfy strict FCC stability rules, but thanks to the invention of digital TBC, U-Matic made it to the broadcast world.
2-inch was better, but it was bulky, expensive and on a wane. 1-inch was better and was quite modern, but it was R2R. Broadcasters wanted something simple, cassette-based, with quick turnaround, and U-Matic fit the bill. Betacam and M-Format eclipsed U-Matic in 1981 and left it in the dust.
First generation of U-Matic SP was not as good as Hi8, but a further couple of generations were, thanks to better S/N thanks to higher tape speed. When Hi8 launched, post houses printed ads like "Shoot on Hi8, edit on U-Matic".
Here are some quality U-Matic uploads (not mine):
And a VHS capture that you may like
Also, if you wonder how a quality transfer of Hi8 looks, here it is, in full 60 fps glory. Hi8 has higher chroma bandwidth than even U-Matic SP, and as such, has higher chroma resolution.
Old Today, 06:39 AM
Really DVtyro? So how is it that you've become this video quality authority here? You assume I don't know anything about the 3/4 U-Matic format or NTSC or how interlacing works? Seriously dude? What I find particularly amusing is how you portray yourself as an authority and critique everything with little regard for the more subtle facts of the big picture be it 4:3 or 16:9.
That being said I made it clear that these were raw captures, no sweetening or other post processing to make them look better, the objective was to show the 3/4 U-Matic format in a real life setting from the lens of a 3-tube camera. If you want to compare my posted video against others that have been sweetened that's on you but again I make no apologies if they don't somehow meet your expectations as they mean absolutely nothing to me. I have been doing video production since the early 1980's and no stranger to the nuances and limitations of the various formats, you are absolutely wrong in your assertion that Hi8 has a "higher chroma bandwidth than even U-Matic SP and as such a higher chroma resolution". Both of these are color under formats with a 100 KHz chroma bandwidth and roughly 30 lines of horizontal chroma resolution despite the actual carrier frequencies being different. Debate this all you want but the fact still and always will stand.
First generation Hi8 may "look" better than U-Matic but that's not the point of what I was doing and I'm at a loss as to why you brought this tangent up in the first place, the only thing you have done so far is muddy the waters with half baked and made up facts. I own both 3/4 U-Matic and one-inch Type-C format VTRs along with BetaSP, DigiBeta and HDCAM tape formats, HDW-500 editor and HDW-F900 camera for half inch and two DSR-1's docked to a DXC-D55WS and DXC-D35WS portable cameras with a DSR-50 as a 1394 feeder deck for DVCAM, all of this I've added over the decades as a freelancer so I do know what I'm doing. I also have five TBC's that handle different tasks as needed, a switcher and most everything else needed to do educational & corporate video production, if you would like some lessons perhaps this can be arranged but they will require your full attention and willingness to learn without trying to prove me wrong at every step of the way. I did a lot of educational production on top of corporate board room meetings, depositions and various other venues going back to the late 1980's when I worked in the service school for Onan corporation. The Onan Emerald RV generator maintenance video was one of my first big productions the summer of 1987.
So back on point.
To reiterate I was not looking to make the old 3/4 U-Matic video look like modern day, it was captured raw, edited using strictly analog methods and uploaded just as it was captured using a Newtek Tricaster Broadcast TC-550 "studio in a box" to show the format as it was then and now. If you want to stomp all over it be my guest as I really don't care, as far as I'm concerned your credibility here as some sort of all-knowing professional guru has missed the mark by a long shot. If what I'm doing doesn't measure up I really don't care. Go back and read Post #47 to refresh your memory if needed.
Respectfully and Sincerely Brett Lee
Old Today, 05:46 PM
I stand corrected, and I am willing to drop my statement regarding Hi8 chroma bandwidth and resolution. A higher chroma carrier frequency of Hi8 compared to NTSC UMatic SP does not necessarily result in a wider bandwidth.
I apologize.
And I made it clear that:
  • It is not possible to watch interlaced video on a progscan monitor,
  • Youtube deinterlaces interlaced video, and does it poorly,
  • Unlike every flatscreen TV set (plasma, LCD, OLED), Youtube converts 60i into 30p, not 60p,
  • Even if you upload 60p, Youtube will convert it to 30p if the resolution is lower than 720 lines.
Thus, to have a similar experience with interlaced video as one had with a CRT TV set, you need to:
  • deinterlace to 60p with a decent "bob" deinterlacer,
  • upscale to at least 720 lines.
What you have uploaded does not reflect the actual look of your raw captures, as both the temporal and spatial resolution have been reduced (temporal is halved, spatial is almost halved, depending on scene). You did not comment on how the car looks.
The videos I linked to were meant to show how analog video converted for Youtube actually should look like. First and foremost, it should be 60p, not 30p. It is not "sweetening", it is making it viewable on a modern platform. No one watches Youtube on a CRT TV, and even if they were, Youtube deinterlaces all interlaced videos.
If you want to demonstrate how good UMatic looks, you need to upload 60p.
