1950 Zenith Porthole Tuner Mistake
My Zenith porthole set was playing great every time I turned it on. The other day I turned it on and there was nothing but raster, no picture from my dvd player. I checked all of the connections and everything seemed fine. I took the cover off of the tuner and very gently rubbed the tabs on the channel 3 and 4 strips with a very fine emory cloth to remove any light corrosion. The picture returned but now I’m getting interference on both channels. Is there anything that can be done to bring back a clear picture again? Any help is greatly appreciated.
Get some tuner cleaner/lubricant. You probably only cleaned the contacts on the individual channel strips. The mating contacts may also be corroded. Just spray both the channel strips and the stationary contacts and cycle the tuner back and forth.
Good luck. |
I might recommend not using any kind of sandpaper. Rather contact cleaner with a stiff rag or cotton swabs. If the contacts are silver plated, any abrasive will remove it.
Abrasive cleaning is a bad idea. Tuner cleaner and or a rubber pencil eraser are the 2 best things to clean tuner contacts with... If you don't have tuner Cleaner sometimes the eraser alone is enough.
You may have to readjust fine tuning after cleaning contacts... Some portholes make it easy, others have this goofy spring loaded shaft that you have to push in each time a new channel is selected to to the fine tuning... Sometimes they put it where you're at risk of touching the metal cone CRT while adjusting it..
"Sometimes they put it where you're at risk of touching the metal cone CRT while adjusting it.."
Being zapped by the anode HV let's you know that you are alive!
I have the remnants of one on the back of my right forearm from 5 years ago that still hurts if I bump it accidentally. What was the thinking behind that design other than keeping amateur tinkerers from ever fooling around in the chassis?
I used a tuner cleaner on the channel strip tabs for channel 3. The picture is better but not like it was. I hope I didn’t use too much pressure on the tabs with the emory cloth. All of the channel strips on the tuner look identical. Could an untouched channel strip be used in place of the one that I tried to clean with the emory cloth? I didn’t take the tuner apart enough to get to the internal contacts.
Each strip is aligned for that specific channel. You just might be be able to use an adjacent channel strip if the fine tuning would have enough range to pull in the other channel. If it is a split sound set, this idea probably won't work.
Thanks to everyone for the helpful advice. I got what I think is a better picture than what it was before. I wiped off the tabs on the channel 3 strip. I adjusted the fine tuning and contrast and brightness. I have to remember the set IS 76 years old!
