#316
#317
http://suzaku.live-evil.org/maggy-solved.jpg
As I mentioned, I'm done with the set for now... But it's still a bit too wide and linearity is off, as for width, S101 adjusts it by swapping in resistors on G2 of the HOT, what effect will raising or lowering the values of them have on width? Someone also mentioned changing the 100 ohm cathode resistor to a lower value, but won't that also lower the HV as well?
#318
You could experiment with a width sleeve. That consists of some thin brass shim stock wrapped one turn around the neck, so it just overlaps. If I recall correctly you get the most width with it removed, and gets less as you slide it into the yoke.
#319
I got a new toy for Christmas!
http://suzaku.live-evil.org/20251218_170449.jpg http://suzaku.live-evil.org/20251218_170532.jpg That and a few others.. I won't be able to set it up till later.
#320
If I knew where to get one! :P
#321
Yet another new toy!
http://suzaku.live-evil.org/ezgif-618c4c9687f96e65.jpg This one will need to be restored. But the Transformer is good, and the 6E5 is strong!
#322
#323
Brittany still working OK, but vertical stability still touchy when first turned on, getting a trio of $35 NOS Sylvania 6SN7GTs seems to have cut the time in half, perhaps even MORE $$$ NOS ones may shave more time off for the sync clipper/leveler vert osc? It seems to be really picky about the tubes in the area, and wants strong ones.
#324
The vertical bug on the set still is nagging me, it works, but not as well as it could. I guess I missed something.
Not sure it I got all the resistors or not. I think I replaced these, or SOME of these. http://suzaku.live-evil.org/vertical...or circuit.jpg http://suzaku.live-evil.org/vertical...circuit-ss.jpg That mica was replaced, with a film cap. Next time I have the chassis out, I will make sure to replace ALL those resistors with new film types, and put in better caps NP0 types, and a Mica one where the .0047 was before, and perhaps I wont take 5-10 min before it's stable.
=^-^= Yasashii yoru ni hitori utau uta. Asu wa kimi to utaou. Yume no tsubasa ni notte. いとおしい人のために Last edited by Yamamaya42; 10-19-2026 at 08:30 PM. |
#325
Wow! Your capacitor tester is older than mine! I have the later version.
#326
![]() ![]() ![]() Nope, not gonna go through that again, not no way, not no how! https://www.ebay.com/itm/206646218880 Not going to touch it.
#327
#328
It's not all it's cracked up to be...
![]() Why is it that 2 times that I have found compatible flybacks, they have been cracked, broken or dropped?
#329
A halloween nightmare! Cracked core!
#330
So, everything that I have looked up on the topic says that raising the value of the 2 resistors that go to the 2nd grid will lower the width a bit, the set has the original 3.9k ones in it 1W, old but still tested OK, and hooked to 10k resistors, to the 2nd grid, the docs say to use the switch to adjust for line voltage and strength of the HOT, it does have some effect on width, thinking of trying 2 4.02 kOhms 2w resistors, that should not have that much impact on HV I would think. And I could always defeat them with the switch.
