That's a GE-branded rebuild. The saga of this set and its original CRT are here on VK: https://videokarma.org/showthread.ph...hlight=blessed
To summarize: The original tube had gone to air. Scotty rebuilt it and sealed all the usual suspect glass metal joins, but it went back to air quickly after it was done. I donated it for testing the helium leak detector at ETF, which required necking it again. The leak was found to be a tiny ding in the metal/metal weld between the faceplate assembly and the bell. When last seen, it was in storage at ETF, marked "Wayne's tube," in hopes that we will have a rebuilding facility some day. I replaced it with an all glass rebuilt tube bought from Scotty just before he closed down, until this 21AXP22A came along years later. --- I should take another picture, as the fine tuning was a bit off, causing the off-color edges on the bars. I didn't notice it that much but the phone camera really emphasized it. Last edited by old_tv_nut; 07-18-2026 at 03:11 PM. |
