Old 01-13-2026, 07:44 AM
tubesrule's Avatar
tubesrule tubesrule is offline
Originally Posted by Dave S View Post
Bob, the story about the “001073” stamped on the chassis is one of those absolutely charming coincidences that always make me smile.
And Daryl, I could be wrong but although Ray Kell was surely often the smartest guy in the room, I don’t believe he was a PhD.
Hi Dave
I think you're right. I remember reading an article that called him Dr. but I don't know that as fact. Doing a quick search turns up nothing on him having a PhD.
Darryl
Converters for obsolete standards:
www.tech-retro.com/aurora-design/legacy.html
Old 01-26-2026, 06:01 PM
I placed a WTB in the classifieds for two matching RCA caps to make a matched set. Another collector came through with some and we made a deal.
I'd all but given up on these ever arriving after being endlessly delay by UPS, but here they are.
I also cleaned out the donor HV transformer box. First, heat to get the old transformer out. Then, cold to make the tar brittle and easy to chip out. Finally, lacquer thinner to remove the residue. It looks reddish due to some rust on top and stubborn paint.
Once a few more supplies arrive in about a week, I'll start restuffing and fabricating.
Old 01-27-2026, 11:48 AM
Old 02-07-2026, 04:41 PM
Did some experimenting today. 8 turns of wire around the primary will get me 1.5 VAC into a 1.5 ohm load. 4-5 more should get me 2.5 VAC to power the 2X2 rectifier filament. The challenge now is to find wire that can handle 2A or more, 2kV or more and fit around the primary. This experiment is using 600 volt wire and there's no more room.
I suppose I can use enameled wire and some Kapton tape. I believe it is rated for 7,000 volts/mil. After all I'm not concerned about the windings shorting to each other. It's the primary and core I need to worry about.
Old 02-10-2026, 12:02 PM
While waiting for another parts order to arrive, I moved on to restuffing the can capacitors.
Very easy to cut them open by rocking a fresh box cutter blade over the aluminum right below the cap lip.
Here's what I found inside.
There appears to be a pressure release value under the cap which should make it trivial to reattach.
I'll try using some big o-rings.
The new caps fit easily inside the empty can.
I'll transfer the original terminal lug to some new tinned brass rod and thread it through the base for the positive.
Which leaves the negative. I might try some aluminum compatible solder or sneak a ground lead out through the base.
Old 02-14-2026, 01:31 PM
It took about 14 turns of enameled wire to power the 879/2X2 tube filament at 2.5 vac. Barely any effect on the HV output of the neon sign transformer.
With a 1mA load, I'm getting 4.6kVAC out. At 1.5mA, it barely drops to 4.5kVAC. So, it seems no need to be concerned about the current limiting core design of the NST in this circuit.
Next, I powered up the 8013 HV rectifier this set came with and it lit up nicely. I then switched to the original 878 type. Holy cow is that thoriated filament bright!
Next up, I'm going to secure the added filament windings, insulated the leads and breadboard both rectifiers with filter circuits and simulated loads for further testing.
Old 02-26-2026, 02:22 PM
Work continues on the power supply chassis. The second anode and focus filter caps have been removed.
That gunk appears to be wax.
Now I can down into this area and really clean it out. Lots of residue I presume from when the original HV transformer died.
Here they are after some rust removal and cleaning. They are oiled filled and likely still good. Made from a steel box soldered closed with ceramic insulated lugs.
I'll test them and try using in my test setup before reinstalling them. If either is bad, I'll try to open up and hide new caps inside. Yes, I know they might contain PCBs.
Each contains two caps with a common lead in them. Used in a PI filter configuration with a filter choke between them.
I don't suppose anyone have a clear photo of the original labels? Mine were already gone when I got the set.
I've also been experimenting with replacing the rectifier tube sockets.
The chassis hole is a bit too small for these more modern plastic and phenolic sockets. Rather than enlarge the hole, I slightly filed down one of the sockets just enough to fit.
Unfortunately, the chassis steel is much thicker than usual so I can't use the snap ring.
I'll likely just go with something that is functional and safe for now while I search for a closer match to the original style.
Old 02-27-2026, 10:48 AM
I tested both caps with a modern LCR meter and a vintage bridge.
Both measure good for capacitance, but the smaller cap used in the focus circuit shows some leakage with only few 100 volts on it.
Should be a dual 0.05uF rated for 2kV or better
I'll attempt to open it up and restuff with a couple high quality plastic film types.
I also received a comment on YT that the focus cap failed and took out the focus HV transformer in the RR-359 at the ETF museum!
I'll be at the museum for the convention in a couple months and will thoroughly examine and document their set.
Old 02-28-2026, 04:31 PM
It was fairly easy to use some desoldering braid and pop the box open. I carefully drained the oil and pulled out the old caps.
Then, I cleaned it out and disassembled.
Old 03-07-2026, 06:27 PM
I just got this cool military grade HV cap from Surplus Sales of Nebraska. It's made from reconstituted mica.
It's also just a tad too big to fit cleanly.
I'll put some of the blame on them. They listed it as 1.75" wide, but it's actually 1.85" wide.
The length is exactly 2.25" as specified.
If I angle it and shave off a bit of the outer coating I think I can cram it in.
More of a concern are the leads.
The common does not connect to the case. It needs to wrap around down to the center lug on the opposite side.
I think I can just manage it.
This project sure is frustrating. So far just about every part has been oh so close, but not quite right.
The power supply in this set is rather creative. Here's a simplified, partial diagram.
My favorite is how they vary the focus voltage by using a big rheostat on the primary on the focus HV transformer.
I suppose they wanted to avoid having to deal with a high voltage on a user accessible potentiometer.
Old 03-18-2026, 11:36 AM
While working on the HV supply, I discovered the Mycalex HV deck had some stress cracks. Probably from the tube being insert and removed over the years plus age.
It's an interesting material. Feels like stone or ceramic, but can be drilled and machined if care is taken.
The breaks were very clean and no damage around the tube pins. So, I figured I try to glue it.
First, I pressed the pieces very tightly together and wicked in some super glue from the back side. It flowed and bonded very well.
I then reinforced and filled in void with slow cure, high tempo grey epoxy cement.
Finally, I gave it a good cleaning. I think it will work.
Old 05-04-2026, 12:34 PM
I have returned from the 2026 ETF convention with a wealth of knowledge and experience. Not only was I able to pull the chassis out of the museum's set, we actually got it working!
It had been restored some 25 years ago, but it had never been properly reassembled or powered up at the museum.
We spent some time pulling and studying the chassis - especially the tuner. Note this set seems to have an FM descriminator circuit added by RCA.
Here's the main coil with windings for the antenna, LO and mixer.
We discovered that the 878 tube had been replaced with an 879 and the focus wire cut. Seems someone was a bit lazy when the chassis were pulled to ship the set to the museum and cut it instead of properly disconnecting it from the screw terminal.
The rest looked OK so we proceeded with a power up in stages.
First, with all the rectifier tubes pulled. All the tube lit up so we proceeded with the HV rectifier tubes then the 5U4s.
Here it is with an 8013A in place of the 878
All was going fine but no raster on the CRT. Eventually someone noticed there was a splotch as it powered down. The led us to discover a bad contrast control. Further, we needed to bypass a resistor to get the brightness control into the proper bias range for the CRT.
OK, raster but no image. We tried direct video injection in the grid of the video amp but that didn't go well. So back to the tuner. The original A305A mixed tube grid cap had broken loose. We subbed a 6D6 and after some more control manipulation we finally had a stable image!
Note this set has some sort of CV326 or some such British military CRT installed in it hence the odd phosphor color.
The thin rubber CRT mask shifted out of place while we worked on the set.
Next time we visit, we'll repair the A305A grid cap, replace the bad contrast control and reseat the CRT mask.
Another curious thing is the mirror in the lid.
This set has a polished piece of (stainless steel) metal and a lightweight lid. You can see some corrosion has started on the right side.
Mine and others have a heavy front surface mirror piece of glass in the lid.
Old 05-04-2026, 12:50 PM
We attracted quite a crowd as we worked on it.
Neat to see the tuning dial is a loverly backlit green. Not going to be easy to reproduce it.
Almost forgot we found this very early style 879 (2X2) tube in the set with a neat, rippled fan filament.
I've been told this is what would have been in mine originally.
Now a new quest to find one!
Old 05-04-2026, 03:34 PM
Old 06-11-2026, 10:48 AM
We will be working on the museum set at some point over the summer and I will gather more information.
Meanwhile, perseverance pays off. It took me a few tries to get there but I finally found a 4 pin tube socket that fits in the RR-359! I will need to slightly enlarge the mounting tab holes, but the phenolic body fits perfectly.
It is an Amphenol SK4P from RF Parts. https://www.rfparts.com/sk4p.html
I recommend perusing their offerings if you are not familiar with the site. They lean towards transmitters and have some interesting vintage parts.
It's in the foreground here. Body and mounting collar are smaller than the industry standard.
Obviously, it's not the same as the original, but will get the job done.
