What I do on Japanese market gear (VCRs mostly) and some vintage TVs is use a bucking transformer. They're basically heater transformers with the leads wired to form a bucking auto-transformer. You can get them in 6V, 12V, and 24V flavors. My line voltage is around 117V on average so I tend to use the 12V bucking flavor...My 12V bucking was originally wired as a boost but I simply reversed the 12V winding for bucking....no sense tying up a variac on a working unit.
Why not just use the heater voltage on a tube restorer?
Hi to all,
"Alastair" in the UK claims (in 2013) to have obtained good results reactivating 1st generation Trinitron tubes (the 12" 330AB22) : https://www.radios-tv.co.uk/communit...ation-updated/ Note: the site is sometimes geo-blocked for security reasons. Best Regards jhalphen Paris/France |
As far as progress on the KV-1320U: I'm pretty far in to the mechanical part of the CRT exchange. I got the chassis and CRT/front panel divorced without incident; it mostly followed the OEM Sony manual instructions, with an exception for some of the wiring on a terminal strip on the CRT shield. But a quick reference photo took care of that ![]() ![]() ![]() Miraculously, none of the yoke plastics or mounting hardware broke! I was very pleasantly surprised... ![]() ![]() I'm thinking once I have the replacement CRT fully dressed I'll start pre-emptively recapping the chassis before putting it all back together. Not having the yoke and CRT in the way gives me really good access to a lot of parts I'd otherwise really struggle with, and I already know most of the set works as it came up with full deflection and snow. More soon...
When you lower your standards, you set a new standard! ISO: Mitsubishi 6CT-338, Sony Chromatron 19C70/100, Yaou "Colornetron" GTC-9, etc... |
The PCB's are hinged so most things are easy to get at.
Zeno
Definitely serviceable in situ, but eh, I have it all apart, why not...
Been trying to do the hardest boards first. The IF-related circuits are a bit tedious with all the soldered shields, but I bought a new soldering iron recently which has been making quick work of it all. Metcal RF irons are no joke! ![]() ![]() I love these 2SC403A's - seen a lot of them in Sony IF/color circuits. The "leads" appear to be nothing more than gold foil. I have a precious few used spares, but am still super careful working around them. I can't imagine how fragile they are...
Very jealous! A decent soldering iron is at the top of my list right now, but I don't think it will be quite as nice as that one.
I've been using the same Digital Tenma station that I bought from MCM Electronics in the late 90s. I never bothered replacing it because it kind of "just works" and it gets very very hot. The big issue is that it takes a minute or two to be usable. Quote:
All we know for sure is that the emissions looked better for at least some amount of time after he did it. It never made it back into use in the scope of that thread |
I'm not taking about CRT testing or restoration there. I'm taking about powering the whole darn TV. You can't power the whole TV from a CRT tester/restorer.
If you wire a 4 wire heater transformer so that one terminal of the secondary connects to one terminal of the primary and connect a power outlet across the other terminal of the seconday and the other terminal of the primary you can make a device that lowers or increases (depending on the polarity of the secondary waveform) the output voltage by the secondary voltage....IE if you have a 24V secondary transformer and a 120V line you can wire the transformer to give you 96V output or 144V output. Japanese electronics designed for 100V don't always like American 125V... bucking line voltage down closer to the rating prolongs the life of the device.
Ah. Ok makes sense. This comment is specifically because OP is restoring a JDM chassis designed for 100VAC input.
If you stick with American SS stuff none of this matters, but I'm mostly a tube chassis era collector.
