Sounds like HVSD ( high voltage shut down) . If you have a variac
try running the set at @95 VAC. IIRC this chassis had a repair kit for the power supply. Too long ago to remember the details. A recap not in order, fix the HVSD first then there are a few caps to change. A wholesale recap usually ends in sorrow ![]() Anyhows they were good sets & odds are it will come out fine. 73 Zeno ![]() LFOD ! |
Thanks! I don't have a variac, could I use a light bulb in series with the power cable for the same effect?
I looked up the part number on the bottom of the chassis, it's a TS-969 apparently. https://www.worldradiohistory.com/Ar...TD-1980-06.pdf A schematic for the board is on page 58 Last edited by blue lander; 02-17-2025 at 11:43 AM. |
Then fire it up for a few seconds. Un power & feel the transistor & see if it gets hot. If so dont go further. If cool do again for 10 sec, 30 sec etc. That will get you started. Zeno |
Sounds like maybe OP should pull and check the components in the PSU. I know in some cases, you're not supposed to directly measure B+, but this set schematic doesn't seem to warrant that, so could start off by checking that is okay?
