Old 01-21-2025, 01:16 AM
Update, January 20, 2025
From Mike,
I have done a complete rebuild of the Video Board. All components were replaced since I had to do a full scrape of the top of the board to remove some kind of residue from previous repairs. Not sure what this stuff is, but it is not rosin from a solder bath treatment. I have found it on all of the P.C. boards of this chassis. I made a special tool from a small razor blade to help in the process. Also, both tube sockets needed to be replaced. They were both crystalized from heat and the socket pins were exposed from the top of the board. I removed the top cover of the I.F. board and it appears to be clear of this strange residue. I notice a small crack on the I.F. board where one of the mounting screws secures it to the chassis. Fortunately it is not in a critical place of the electronics. It is only a ground, and the ground is good. It bothers me a bit though, that this made it through the assembly line without being caught. However, before this chassis is finished, I will be beefing up all of the grounds on the P.C. boards with wire soldered to the chassis from ground points on the boards. This insures a good ground from P.C. board to chassis. From the looks of the I.F. board, there will not be too much to do in the way of component replacement. I may replace both the Audio and Video detector diodes due to their age but that will probably be all unless I run in to some surprises during R.F.I.F. allingnment.
The picures are as follows:
Pix 1 Video Board before rebuild
Pix 2 Scraping with tool.
Pix 3 Sockets removed and board 1/2 scraped of residue.
Pix 4 Parts replced on Video Board
Pix 5 Video Board after rebuild
Pix 6 Video Board after rebuild with tubes installed.
Pix 7 I.F. top of board with cover removed
Pix 8 I.F. board with crack at mounting bolt.
Yet to do:
Add grounds to P.C. boards.
Replace several more caps in main chassis
Make screws for Yoke Clamp. "special"
Make up a back cover.
Add H.V. cover that is missing.
Do AFPC alignment of Chroma Circuits
Do R.F. I.F. alingment check and adjust as needed.
Cheers, Mike
https://visions4netjournal.com/wp-co...4-rebuild.jpeg
https://visions4netjournal.com/wp-co.../Scraping.jpeg
https://visions4netjournal.com/wp-co...-scraping.jpeg
https://visions4netjournal.com/wp-co...-Replaced.jpeg
https://visions4netjournal.com/wp-co...r-rebuild.jpeg
https://visions4netjournal.com/wp-co...ith-tubes.jpeg
https://visions4netjournal.com/wp-co...-Top-view.jpeg
https://visions4netjournal.com/wp-co....F.-Crack.jpeg
