Old 12-23-2024, 09:07 PM
cj_reha's Avatar
cj_reha cj_reha is offline
Great to see this! When you first see one of these (which I did in 1965 at the NY World's Fair), you might suspect it's transistorized, but no, it's a tube room heater.
Regarding the mirrors, I suspect the coatings will be peeling like the one that was at ETF, and if they aren't, I would really hesitate to try cleaning the coated side.
Do you know if the three tubes have red, green and blue phosphors, or are they white with the color totally due to the mirror coatings? I can't remember.
Thanks! This set is the reason I asked you about the pictures you took (and the reason I mentioned it in the OP)
If I find the peeling in mine I wonder if it's worth calling around to local glass shops to see if any of them do dichroic coatings? Kind of a weird ask, but I can try...
The CRTs are actually R/G/B colored phosphor, they're each individually marked with their respective color.
When you lower your standards, you set a new standard!
ISO: Mitsubishi 6CT-338, Sony Chromatron 19C70/100, Yaou "Colornetron" GTC-9, etc...
