Old 10-14-2024, 09:49 PM
"With this setup and the scope in XY mode, I get a trace that isn't flat but the amplitude is very low where it does deviate and changing the signal strength through the available voltages doesn't affect it much. I do not want to touch the T-1 and T-101 transformers used to adjust this until I get some feedback I have all of this correct."
The voltage you set with the potentiometer is the IF gain control. The resulting gain will depend on the exact gain control characteristics of the particular tubes you have. You can try adjusting the potientiometer slightly to get the output signal strength you expect/need.
