Old 10-14-2024, 03:41 PM
redk9258 redk9258 is offline
Here is a picture of the mechanism..
https://web.archive.org/web/20201126...com/mbk-42.htm
You do not have to disassemble anything needing re-calibration.
You may have to unsolder a couple of wires and maybe drop the capstan motor down to get clearance to get at the mode switch. It may be possible to get deoxit in the switch without disassembly. If you take the cam plate off - or whatever it's called, make sure you understand the timing marks. They are critical for reassembly. Also pay particular attention to where each screw comes from. They must go back in the same place!
