Old 09-11-2024, 08:51 AM
This chassis was built for a short time. It was the last modular
RCA & last delta tube RCA. Saw very few of them. You will
need a manual & if you can find a training manual that would
be best.
It does have an interesting one try kick start. Also IIRC two ground systems,
One for power supply / HV and the other for the main chassis / tuners.
Good luck
Zeno
Old 09-11-2024, 09:07 AM
https://www.ebay.com/itm/31410664125...Bk9SR-j0j5a8ZA
Thats the SAMS for the set. Paper copy much better than a $22 down load !
Old 09-11-2024, 10:29 AM
damen's Avatar
damen damen is offline
In that 4th picture down you posted, check that 15 watt rectangular fusing resistor just behind the interlock connector. That going out will produce a "hot odor" and cause the set to be dead except for the dial lights and the degausser noise.
