+1 for the poor quality of these things.
The 16:9 fixed is a disrespect with history. BTW, even if you watch a modern content being 4:3 (like a Simpson cartoon in the streams), is in reality 16:9 with side bars. Then you want to reproduce it with a 4:3 monitor or TV, and it have side AND horizontal bars ![]() ![]() ![]() ![]() ![]() almost like a PIP in the center ![]() Unless you download a extension to force reproduction to cut permanent black areas, like I use with my notebooks connected to old TV's.
So many projects, so little time... |
The unit does not include a format rescaler. For the price you would not necessarily expect it to. Eg you do not have the facility to letter box or center cut on a 4:3 display using the inexpensive box. There are other ways to better handle this. The ones who disrespect history are the ones who format 4x3 content as 16x9 with no side bars! |
Ah... well noted. Perhaps a little of language issue (for sure, my English are not sooo good), but I believe I hasten too much to write and oversimplified...
For sure, el-cheapo devices will never have these facilities. But anyway, I saw some only accepting wide resolution settings... go figure. My concern is not about commentaries from you and our friends here; is about the following: In general, I regret the lack of options for the legacy monitors. It can't be too difficult for programmers, ie. I don't understand the impossibility to zoom an originally 4:3 video on a... 4:3 monitor (results like I said, everyone can try, using every stream or newer Youtube videos). Since it are coded with 720x480 with side bars, and not 640x480 (for older ones). It will have bars at all dimensions, with reduced dimensions, unless one download a plugin to cut the bars and displays as a 640x480 video. For the 16:9 monitors, are a blessing that displays the content with correct aspect ratio, ie, with side bars. I concur 100% about the displaying these content in newer wide screens: I watch old things like eg. Simpsons with side bars when using modern wide screens, preserving the original A/R. EDITED*
So many projects, so little time... Last edited by Alex KL-1; 09-06-2024 at 02:53 PM. Reason: Missing info, typo |
