Old 09-05-2024, 03:19 AM
Claustrofob Claustrofob is offline
Ok, thanks!
Since L3 stated 140V MainSupply, I thought it was safe to measure. Will be careful in the future.
Yes, the EW MOSFET 7400 is driven by the EWdrive coming from the µC.
As you can see, S5 is the signal driving the MOSFET, and as I stated in my first post. My S5 signal is a bit too high, right? almost 1.3Vpp. Should be around 0.7Vpp right? And also 4V when measuring with DMM.
I've been playing with resistor, before and after the MOSFET. Although I did put resistors in parallell so I managed to destroy the MOSFET doing that. I should have put the in series or swapped them out. What I found was if I decrease the gate voltage the pincushion becomes more prominent. Which makes sense.
Any recommended resistors that I should try changing and recommended values?
