Old 08-22-2024, 10:18 AM
Thanks. Here it is with the 16EP4 installed. Cool how the image appears to be emerging from the end of the cone. Quite different form the al glass CRTs I usually work with.
Normal vs porthole mode. Instant weight loss
Old 08-22-2024, 11:57 AM
John Marinello's Avatar
<-- "Byron"
Very nice, Bob!
Hopefully you'll be able to do your magic on the damaged speaker cloth??
I know some will gag when I suggest this, but I've used a little dish soap and water, with a soft brush to clean the insides of the cabinets. just a quick job and dry it off. Never had it harm anything, and the results are amazing. Clean and fresh smelling.
Old 08-22-2024, 02:05 PM
Unfortunately, the fabric is torn and distressed. Short of replacing I don't there is much I can do.
Meanwhile, I primed and painted the screen bezel with some metallic aged brass I had handy. This set had been a rental for plays and such and abused.
Fairly close to the original. Maybe bronze would be better? Either way, I'll paint the control doors to match.
Old 08-23-2024, 11:54 AM
<-- "Byron"
This cloth is close:
https://www.ebay.com/itm/39231363662...ef01ab592a0aab
Old 08-23-2024, 01:04 PM
Thanks. Found the same pattern in a smaller size from a domestic supplier. Should be here next week.
Old 08-23-2024, 08:07 PM
Not entirely happy with this "aged copper" but it's better than the "aged brass"
Old 08-24-2024, 02:22 AM
If it looks good and is proper speaker grille cloth please post the source. My porthole (and I suspect several other models) uses it and mine is just as torn up as yours.
Old 08-24-2024, 01:16 PM
I got it here. Diamonds run the wrong way, but it's just tall enough to rotate 90 degrees and fit.
https://www.ebay.com/itm/375306979157
Old 08-24-2024, 07:31 PM
<-- "Byron"
Ever check auto parts stores for touch-up paint?
Old 08-24-2024, 08:35 PM
No, but I should. Seems like 'champaign' would be a good match. The control doors are in better condition than I thought and I will not be painting them. I'll try to bring one with me to a store and find a better match.
Old 08-25-2024, 12:51 AM
Some of the auto parts stores can scan a sample and mix a custom matching rattle can the same way a hardware store will make you a gallon of latex to match a decades old chip from your house...
Old 08-26-2024, 03:04 PM
Just cleaned and polished the controls doors. Color difference isn't as bad as I originally thought.
Old 08-28-2024, 02:28 PM
I think we have a winner. Grill cloth just arrived too. I'll check it out when I get home from work.
Old 08-29-2024, 09:33 AM
Here's the grill cloth. Not quite the same, but given how hard it is to get cloth these days, it's a good option.
Old 08-29-2024, 03:19 PM
Very happy with the new paint. The controls doors are original.
Only took three tries to get here
