Input value is 1V P-P confirmed by a Leader 5860C waveform monitor and it's terminated at the input amp itself. Problem I'm chasing is a lack of sync and high whites that's throwing off the 1st video amp of the set causing what appeared to be an overload condition thus my attempt to use the AGC to stabilize the input amp. Problem I seem to be having is a lack of DC for black ref and this is killing the sync. Picture one is the clean signal coming from the Phil Nelson 12AT7 input amp feeding directly into the pentode grid of the 6MU8 1st video amp. White is clean & sharp but the black is lacking, picture two is the output of the 1st video amp at the plate, the little overshoots are products of the sharpness coil on the end of the cathode. Picture three is the 1st video amp of the Magnavox itself, this has been completly isolated from the detector & 4.5 MHz trap and has a 470K grid resistor tied to ground. The Phil Nelson DC restoration circuit I'm using has the 22K resistor and 10uF capacitor that was described in the modifications. The big question I have is: what am I doing wrong here?
1st Image: https://i.imgur.com/3jeOfbw.jpg 2nd Image: https://i.imgur.com/Jvlb1kX.jpg 3rd Image: https://i.imgur.com/85tGtdD.jpg Last edited by ARC Tech-109; 08-11-2024 at 12:10 PM. Reason: because I wanted to. |
