Old 06-21-2024, 05:35 PM
luRaichu's Avatar
luRaichu luRaichu is offline
NIGHT STALKER
Are you sure this isn't a termination issue? Do the retrace lines appear on a blank raster (no video)?
I had this symptom when trying to hack an RCA connector onto one of those 5" b/w Sony Watchman sets, so I could have video in. Retrace would appear only when fed through an external source instead of the tuner. I think you needed to slip a resistor in between the RCA and the IC pin so it would be terminated properly, although I never tried. Could've been something on the neckboard too.
We're all in the same boat.
Old 06-21-2024, 05:41 PM
bhegges bhegges is offline
old_tv_nut and Username1 you both are correct, thank you. There was a G1 short on the blue gun. Not sure if this was related but when I lifted the tube from screen facing up which is how I worked on removing the cataract to screen face down to install the tube I heard what sounded like a spec of something in the tube rattle.
Maybe unrelated, note I had fully tested the tube earlier and it passed so something during handling caused the short.
Old 06-25-2024, 04:41 PM
If there is something floating around inside you could always place the tube face up again, or otherwise, and try tapping around the neck while connected to the tester.
