Old 03-08-2024, 11:39 AM
pac.attack76's Avatar
Stuck in the past
The 4 digit model ## is useless. Look for the long number on
a plate, format is ###.###### its the source code.
First 3 digits are the MFG ( Warwick in this case) then look up in Sams.
The Horz out is expensive so check the CRT first.
Also cant be sure but the HV cup looks chewed up & the shielding
is missing......
I had a feeling that 4 digit number wasn't gonna be right. Only thing I could find. I don't see anything on rear cover and not sure if it has anything inside. Could it be on chassis anywhere? I did notice that cup had saw tooth marks. Done at factory? Is shield mandatory?
Genesis does what Nintendon't
