Old 09-19-2023, 04:21 PM
Tying this topic subject to your last in this series: because of a phenomenon known as grid rectification tying grid to ground or some DC bias source through a high-ish resistance (enough to bleed off the miniscule grid rectification current, but not enough to load down the AC signal too much) is important. If you leave the grid with no DC path electrons emitted from the cathode will accumulate on the grid and bias it positive until the tube redplates and fails or plate load resistance limits current. Also some waveshapes can create their own bias through grid rectification...In an audio amp that will still eventually lead to replacing, but in a TV horizontal circuit where the output tube gets a constant amplitude and waveshape osc signal at it's grid engineers frequently used grid rectification to bias the tube without need for another resistor. Grid leak detectors in 20s radios and some hidden DC restorers in some TVs work off of grid rectification.
