#31
One thing I'm curious about, how do you get the chassis out of the cabinet on this TV?
I know with my past experience with working with color TVs (small portable color sets from the 1980s) is that you can't tip color picture tubes face forward because you can ruin the picture tube, and the way the chassis is fastened to the cabinet in this TV it seems like the only way to get to the screws is by tipping it on end but with this being a rather heavy solid wood (pecan wood?) cabinet its going to be kind of tricky to get the cabinet tilted on its side without damaging anything. Any advice on how to do this safely without risk of hurting myself or the picture tube or the cabinet? Thanks for your assistance. |
#32
I haven't heard of problems caused by tipping a picture tube forward. Camera tubes, yes, but not picture tubes.
#33
Any ideas as to what I was experiencing and what would be the best way to avoid that? |
#34
Several ways to handle chassis
GOOD Remove legs if it has them. they either unscrew or twist off. Put the set on its side & remove all but one rear chassis bolt. The chassis will swing out to work on. BETTER Same idea. Put TV on bench upright with a few feet behind it. Find a box about the same HGT, pull chassis & flip out onto box. BEST A test jig but you dont have one ! BTW the purity will be way off while on its side running. Also just be sure you dont pull wires too tight. Take it slow. 73 Zeno ![]() LFOD ! |
#36
For chassis removal I forget if the D12 was this way(I think so but it's been like 5 years since I had mine apart), but the D16 definitely is....On Sylvania sets of that era the chassis slides into 2 side rails and locks to those rails with 2 rear facing screws. Remove the screws and unplug all wires and the chassis just slides out the back.
I've never worked on 80s inline sets or seen what you describe. Delta gun sets like this Sylvania don't care about orientation* and replacements were shipped face down. *In service they would sometimes need purity adjustment and or degauss when moved from facing north-south to east-west but no permanent issues otherwise.
#37
And thanks for the advice for how to go about removing the chassis from the cabinet, this TV I'm working on does have legs but I'm not sure if I want to fiddle with trying to remove them and trying to move this TV to my work bench in the basement, as it is kind of heavy. so I think I'll try Electronic M's Advice and see if I can just slide the chassis out of the cabinet.
#39
OK thanks for letting me know.
#41
UPDATE: I finally got around to removing the chassis from the cabinet and I tested the electrolytic caps and they all tested good yet according to my ESR Meter, and that would make sense seeing as the TV still had full screen deflection.
I also poked around and tested a few of the resistors on the various boards in the TV and the resistors for the most part tested within specs yet, those two 68k Ohm 2W resistors were the only resistors that measured out of tolerance and so I put in an order for some over at Digikey (because Mouser didn't have any 68k Ohm 2W Resistors in stock unfortunately) also the two 68k Ohm 2W resistors were the main resistors you guys said would give me the most trouble. I also was able to clean the pots and the switches better with the chassis out of the cabinet. |
#42
UPDATE: I finally got those two 68K Ohm 2W Resistors replaced.
But I have a question about a couple of capacitors I saw in the chassis that look like they might be paper caps but I'm not sure because there were film caps that looked like these types of caps as well, and plus it seems a little odd that they would of been using paper caps in the late 1960s when Mylar/Film caps were the predominate type of capacitor in use by that period in time. See pictures below. |
#43
OK, so I've pretty much replaced every single tube in the TV except the Vertical Output/Vertical Oscillator Tube which is a 6LU8 tube which I unfortunately do not have in my stash, and the Color Output Tube which is a 6MD8 tube, both of which are compactron tubes and both of which I do not have access to in my tube stash; this is odd because all of the other tubes in this TV I had at least one or more of in my tube stash, and most of them were Sylvania branded tubes ironically enough.
Unfortunately all I'm able to get the TV to do right now is to do a barber pole effect when I have the color turned on, and the vertical isn't locking in at the right frequency, its running at half frequency right now (where the picture is showing a bar in the middle and the top half of the screen shows up at the bottom and the bottom half shows up at the top half of the screen.) I've tried adjusting the height and linearity controls on the back and it doesn't seem to help much (which is why I'm thinking the Vertical output and oscillator tube is either weak or bad.) I'm guessing that the barber pole effect (the color not locking in) is either due to a bad color output tube, a bad 3.58 MHz Crystal, or the color demod transistors are bad. Last edited by vortalexfan; 08-10-2023 at 01:01 AM. |
#44
Barber pole effect is a color oscillator/AFC adjustment issue. The oscillator is running, so the crystal is likely OK. Color demod and/or color outputs cannot cause this.
Lack of oscillator lock could also be caused by burst gate/burst amplifier problem. |
#45
In the vertical circuit I would look at out of tolerance resistors and maybe leaky capacitors.
Having owned 3 different color Sylvanias I've found that when the vertical is off frequency subbing the vertical tubes usually doesn't help.
